Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-07-2008, 12:44 AM
chad85's Avatar
chad85 is starting off with a positive reputation.
Unhappy 85 dash pad
Anyone know where I can find a tan dash pad for my 85? Ford dealers sell them but they are 500 bucks and only come in gray. I havent seen anything else but those Coverlay overlays which I don't want to use. Of course junkyard trucks all have trashed ones. Any ideas?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-07-2008, 05:06 AM
srercrcr is starting off with a positive reputation.
Ebay if you have patience.
__________________
Steve Robbins
'83 XLT Super Cab Long Bed 300-6 (20 mpg hwy) 4OD 3.08, one-owner ordered from the Factory in May '83 with a page-full of options, 175000 miles, all stainless exhaust. Take a look.....
http://s45.photobucket.com/albums/f88/srercrcr/Ford%20F150/?action=view&current=FordF15083.jpg
  #3 (permalink)
Old 06-07-2008, 06:44 AM
81-F-150-Explorer is gaining momentum as a positive member of FTE.81-F-150-Explorer is gaining momentum as a positive member of FTE.
Or you can paint the Ford one with a vinyl color spray, to match.
If the dash pad is not too badly damaged there are ways of repairing them, either by hire, or do it yourself kits sold in stores. One is usually expencive, and the other doesn't always give you satisfactory results.
  #4 (permalink)
Old 06-07-2008, 10:54 PM
biga17133's Avatar
biga17133 is starting off with a positive reputation.
The overlays aint half bad if you dye them and use something to hold it down till it dries(foam cushions) against the window works great and they look good at least the ones i;ve did ....
__________________
Allen
  #5 (permalink)
Old 06-07-2008, 11:07 PM
joestratton1 is starting off with a positive reputation.
NPD (an fte sponsor) sells a dash topper. it fits well, but mine (blue) did not match color perfectly. maybe you can find a color match paint if you are picky. pull original pad off, trim and glue down out of vehicle. $87 and change. Be careful of pads you find at the junk yard, sometimes they look really good, but are very thin and brittle and will fall apart immediately!
Good luck
joe
  #6 (permalink)
Old 06-07-2008, 11:21 PM
85F150302HO is starting off with a positive reputation.
i have a catalog that you can order any of those interior parts from...in any stock color and cheap!!....iirc a door panel was like $20! anyway, when i go home i'm try to find it and pass on the info.
__________________
1985 F150 302HO/AOD
1993 F350 460/ATX-2wd Crew Cab Dually
1985 Honda Prelude 1.8L/MTX
1998.5 Ford Contour SE Zetec/ATX www.contour.org CEG Member tredse1
1957 Mercury Montery 312/Merc-o-Matic(Push button tranny)
  #7 (permalink)
Old 06-08-2008, 07:58 AM
uncle.stosh's Avatar
uncle.stosh is gaining momentum as a positive member of FTE.
Quote:
No one makes an aftermarket dash pad. Charcoal from the dealer or junk yard are your only choices.
Trust me, I've looked every where.
I may have a spare saddle tan dash. I'll let you know tomorrow.
__________________
I live in the salvage yard.
Pennsylvania Chapter Member
  #8 (permalink)
Old 06-08-2008, 09:56 AM
NumberDummy's Avatar
Ford Parts Guru
NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.
Quote:
The only padded dash available for 1985 (and 1986's) is Charcoal, the rest are obsolete.
E4TZ1004282B0P .. Charcoal Padded Dash (note that the Ford part numbers suffix is B0P, not BOP)
MSRP: $488.57 / ftepartsguy.com price: $351.77
Two Ford dealers in the US show they have a quantity of one each of these charcoal padded dashes:
Sopp Ford in Los Angeles, and Grande Ford Sales in San Antonio TX.
__________________
Bill / Retired Ford Parts Manager ~ 1962/1997
Part Number Research: Trucks: 1928/2002 / Cars: 1928/2003
1963 Galaxie 500XL / 1965 F100 / 2008 Fusion S / 2008 Edge SEL
  #9 (permalink)
Old 06-08-2008, 03:44 PM
NumberDummy...can you share a link to the dealer inventory site?
__________________
Steve Robbins
  #10 (permalink)
Old 06-09-2008, 04:09 AM
Ford Parts Guru
Quote:
Sorry, I can't do that. As a favor, a former co-worker gave me the access code. I can't share it.
__________________
  #11 (permalink)
Old 06-09-2008, 05:20 AM
5851a is starting off with a positive reputation.
I actually cheaped out and used a rear speaker grill from an 86 Escort, didn't look to bad but the only place mine was torn out was the speaker opening.
  #12 (permalink)
Old 06-09-2008, 10:13 PM
doug1222556's Avatar
doug1222556 is starting off with a positive reputation.
I gotta see that. All the aftermarket door panels I've seen are over $100.
  #13 (permalink)
Old 06-10-2008, 01:43 PM
rowdyredneck's Avatar
rowdyredneck is starting off with a positive reputation.
Vinyl spray paint works great...I looked all over for a decent pad and the only one I could find was red. I sprayed it with a few coats of gray vinyl paint and it still looks great after over five years.
__________________
'92 F-250 XLT 4x4 7.3 diesel 5 speed
'88 Ranger STX 4x4 2.9 5 speed
'87 F-150 4x4 300 4 speed
'84 F-250 XLT 4x4 460 ZF 5 speed conversion
The Swamp Rat: '89 Chevy S-10 2 wheel drive body mounted on a shortened and modified '75 Chevy K-10 4x4 chassis.
My Pictures
  #14 (permalink)
Old 06-10-2008, 04:02 PM
If you look in the classifieds in this forum, under 80-86 parts and vehicles for sale, you will find ads from 5/15 and5/16 from members parting out their vehicles. You might try contacting them and see if either has a dash pad worth using. I bought mine here for $30.00, black and perfect, and plan on painting it blue along with most of the interior parts. It's worth a shot, and as far as spraying the color on, at least one outfit offering aftermarket door panels, (I think it may be JC Whitney), sells black and charges $10. more for colors and states in their listing the colors are painted.
  #15 (permalink)
Old 06-10-2008, 04:40 PM
RED BOMB's Avatar
RED BOMB is starting off with a positive reputation.
I LIKE TO ORDER PARTS FROM LMC TRUCK
THEY ARE VERY CHEAP BUT THE PARTS A DECENT
Victoria British - Catalog FD - Page 86
USE THIS WEB LINK THEY HAVE DASH PADS BUT YOU HAVE TO PAINT THEM BUT FOR 50 BUCK HEY
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
