Convert a 1978 f250 to a rollback tow truck - Ford Truck Enthusiasts Forums
Old 06-06-2008, 03:32 PM
jason867's Avatar
jason867 jason867 is offline
jason867 is starting off with a positive reputation.
Hey guys.
As some of you may or may not know, I recently acquired a 1978 F-250 Custom 2wd long bed reg cab truck. It has a 351m mated to an auto C6, and a dana 60 in the rear. I bought it for the bed to replace the rusted one on my nice 78 f250. The truck itself runs great.
Anyways, I've been wondering what to do with the rest of the custom. I've finally settled on putting a rollback flat bed on it so that I pull cars onto it to transport. I realize that this is a big project that may be beyond my capabilities, as well as those of the truck in question.
I have a fair bit of scrap metal to work with, and I can afford to buy more. I have some welding skill, lots of time and patience, and a knack for being creative...
I don't intend on this truck carrying anything heavier than itself. I realize that I will be maxing out the carrying capacity of the truck. But I believe that I could easily haul any small to midsize car, and a good variety of vans and trucks.
I don't intend on using this commercially, just for personal use only.
Anyways, do you guys have any opinions on the matter? Any suggestions?
Here's a couple of pictures of the truck, there is more in my gallery.
I look forward to hearing your comments.
Old 06-06-2008, 03:59 PM
Blue Bomber's Avatar
Blue Bomber Blue Bomber is offline
Blue Bomber is starting off with a positive reputation.
cool idea!
Old 06-06-2008, 04:01 PM
NOCO77's Avatar
NOCO77 NOCO77 is offline
NOCO77 is starting off with a positive reputation.
You'll be going beyond just maxing out the truck's gvwr. Don't forget the weight of the rollback you want to build when doing your calculations. Gvwr minus weight of the vehicle with full fuel and occupants equals max. cargo weight. The max. cargo weight is the most you can safely haul on the vehicle. You will probably need a dual rear axle with beefed up brakes at a minimum. Then you will need to get it all built complete, load it up with your winch (or other form of come-along) tie-down straps and/or chains & boomers, etc. and get it weighed to see what capacity you've got left - my guess is, not much left to play with. Don't take this wrong, but also don't take this lightly - the fines and penalties for running dangerously are tough to swallow!
Old 06-06-2008, 04:06 PM
jason867's Avatar
I'm well aware of that. I haven't yet calculated all the weight math. I'm waiting on ford to send me a build sheet that hopefully will tell me the gvwr. Then I'll go from there...
If it could reliably haul a small to midsize car then I'd be very happy with that alone...
[edit]
I was doing a some google searching of a simliar type of truck with a rollback bed. I did find quite a few f350 trucks of various years that had a rollback bed. They had a single axle in the back with dually tires. I'm guessing they were a little beefier than a dana 60 (dana 70 or some such) Along with beefier brakes and engine cooling accessories.
Everything between a f250 and f350 is the same except for the brakes, springs, and sometimes axles (at least in these 1970's trucks) So with a little money and elbogrease mine should be comparatively capable.
By the way, I don't plan on having the bed actually tilt back. It will be permantly fixed, but will instead have an extended angled portion that will have detachable ramps. That should avoid a little weight from the hydraulics and such.
That's the plan anyways...
Old 06-06-2008, 04:56 PM
seventyseven250's Avatar
seventyseven250 seventyseven250 is offline
seventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud of
Quote:
The GVWR should be listed on the data plate inside the drivers door.
Also, you may need some kind of frame extension to support the back of the rollback bed. Get the lengths of some common cars before you start designing the bed.
Good luck!
Old 06-06-2008, 05:28 PM
jason867's Avatar
The plastic coated tag is long gone. The metal tag on the door itself doesn't mention anything about weight, unless there's some code for it...
I was already contemplating frame extensions, I know of a scrapyard around here that sells cheap metal scrap. I may have to pay them a visit...
Old 06-06-2008, 11:29 PM
73f100shortbed 73f100shortbed is offline
73f100shortbed is a splendid one to behold73f100shortbed is a splendid one to behold73f100shortbed is a splendid one to behold73f100shortbed is a splendid one to behold73f100shortbed is a splendid one to behold73f100shortbed is a splendid one to behold73f100shortbed is a splendid one to behold
Not answering your question in the way you might want, but why not make a nice flatbed for it which won't be as heavy as building a rollback and then setting it up to haul a single car trailer or car dolly to haul your cars around. I think you might stay more in your weight limits that way and you won't have to convert to dually wheels or anything like that.
Old 06-07-2008, 12:22 AM
Randomtasker Randomtasker is offline
Randomtasker is starting off with a positive reputation.
Man I hate to rain on anyones parade, but Up here in Illinois, If it's a rollback, it has to be insured as a commercial tow vehicle, which must be plated correctly, insured properly, wtc, or they will tag your but. Not to mention a 3/4 ton isn't considered by authorities as robust enough for that kind of service. I love your enthusiasm, but unless you live on a farm or want to use it only at a racetrack to relocate vehicles, the pig probably wont fly no matter how cool you make her. Darn government!
Old 06-07-2008, 05:06 PM
jason867's Avatar
I'll probably just end up putting a flat bed on it...
Maybe I could rig up something to lift and tow the front end of a vehicle...
Do you guys reckon a wooden floor could be built strong enough to support a midsize car while saving a significant amount of weight? If that's a stupid question I apologize for my stupidity..lol
I had planned on building the bed as lightly as possible. For the floor I was going to use that diamond shaped thick steel mesh that's often used for small utility trailers. I was going to support that with several pieces of angle iron and/or c-channel. For the bulkhead behind the cab I was just going to weld together some 1/4" x 3" steel together, like something you'd find on a forklift. Then just a basic winch, some tow hooks, and then buy a pair of steel ramps and modify them to hinge off the end of the angled portion of the bed...
I don't know, I'm gonna think it over more and do some math...
Old 06-07-2008, 07:32 PM
That steel mesh isn't terribly strong, so it would be easy to make a wooden floor as strong as that. The problem is that you'll need a fair bit of structure underneath to support the wood or mesh. It's that structure that is going to be the heaviest part.
Old 06-07-2008, 08:55 PM
You can always go this route.
SNEEKER - Pickup Model
Old 06-07-2008, 09:39 PM
X36 X36 is offline
X36 is starting off with a positive reputation.
Hey just my 2 cents ,but I'd do what 73 said.Turn it into a tow rig.With a nice trailer or dolly.The DOT are like ****'s If u notice there are NO 1 ton or less ramp trks used by tow companies at all anymore.You'll stick out like a sore thumb.Even if u build to come in under GVW with what u make for a bed and a sm car.They'll get you with the tires.U wont be able to find (within reason) 6 tires that will be able be properly rated fo the weight.I've been down this road.1st was a steel bed,then aluminum bed,then they got me on the tires.After that I went to a f600 and no more problems.Good luck which ever way u go
Old 06-07-2008, 10:30 PM
jason867's Avatar
Here's a Cheby rollback that someone owns in my neighborhood.
That looks like a 1 ton truck to me. It's got duallys in the back, and it has stow-away ramps that slide under the bed. It does have a very long wheelbase. Mine would be as short as I could get away with...
[edit] That bed does not tilt I believe...
Old 06-07-2008, 11:40 PM
Technically that's not a rollback. Just a car hauler. Tell your neighbor its not the best idea to leave cable just flopping around. It should remain tight at all times LOL.
This is a rollback. Back tilts off truck. This was taken in RI when I towed a Ford box truck back to NJ. This was one of those "I bet it can't be done" type things. Boy was my boss wrong.
Old 06-08-2008, 10:58 AM
jason867's Avatar
That's the first time I've seen cable laying loose on that truck actually.
Semantics aside, that's more or less what I had intended to create, although significantly shorter... I never intended on the bed actually tilting backward. It would just have an angled portion with slideout ramps. Heck, I might be able to do without the angled portion period... I'm not sure if the angle would be too sharp for some cars....
So now that we're clear on what I had intended to build, is it still going to cause me trouble with the gvwr and the dot and whatnot? Basically it'll be a long flatbed with an angled portion and ramps....
What is a Snow Plow Worth? duphofff 1967 - 1972 F-100 & Larger F-Series Trucks 9 12-21-2011 06:49 AM
Pictures from Woodies on the Wharf 2011 badger_hound 1948 - 1956 F1, F100 & Larger F-Series Trucks 23 08-27-2011 04:46 PM
All Cleaned Up... WARNING Lots of Pics. cdrmotorsports 1999 to 2016 Super Duty 22 09-03-2010 01:02 PM
My 2009 F-150 Platinum morgan867 2009 - 2014 F150 56 01-01-2009 03:59 PM
dirty/salty trucks i eat hybrids Excursion - King of SUVs 37 01-12-2008 08:07 PM
Tags
1978, 34, 4x4, car, convert, converted, converting, converts, curb, f250, ford, hauler, rollback, rollbacks, ton, tow, truck, trucks, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
