How many different core supports are there for the 61-66?
How do you tell the difference?
Will core supports for the f100 2wd fit 4wd?
What's interchangeable?
__________________
Staying low for now
64 lowered longbed
Robert
I thought there were only 2 styles, 4x2 and 4x4. They aren't interchangable as far as I remember. With that said, DC has a picture of one in their catalog for you to compare, it's for a 4x2 model though.
__________________
Mark J. Covill
"I'm not handicapped, I'm handicapable!"
'64 F-100 Shortbed 460/C-6
'03 F150 Shortbed 5.4L/4R70W/3.55 LS
Author of the disc brake article for 57-64 F-100's
I know the ones for the 65-66 2wd has different brackets for the inner fenders. To my knowledge they don't repop 65-66 yet, but you can take and weld the brackets from the old one on there.
I have used a 2wd core support on my 66 F100 4x4, there were small differances, but overcomable. I did go back to the 4x4 core support after it was repaired.
__________________
Allen D
1966 F-100 4x4 with 67 Fairlane GT 390 and Toyota power steering
1990 Areostar 2wd XLT ext
1991 Areostar 4wd XLT ext
1967 F-100 2wd with auto trans(now for parts)
1980 Bronco with 460
1968 F-350 exforest servive crew truck
1964 Galaxie 500 with 428
Dang it I misread your original post thinking 61-64.
__________________
Mark J. Covill
So then 350 on up are a different animal? Does any core supports from the 61-66 f100-f250 fit a 350 on up?
I noticed on a 350 that the main bolts bolting to the frame were spring loaded what's this purpose? are these hard to come buy?
__________________
Staying low for now
64 lowered longbed
Robert
is there a way that some of the more popular Q and A can be put at the top of the list ...like a sticky and just stay there permanent ???
The core support would be a prime example of a question to be put there.
