Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Ranger & B-Series
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 06-16-2008, 12:28 PM
pawpaw has a good reputation on FTE.pawpaw has a good reputation on FTE.
No need to pull the battery cables if you used a code reader or scantool to reset the computer.
__________________
99 Ranger 4dr 4x2 4.0L 5spd auto 3.55L/S Payload pkg2 tow pkg
Details are trifles, but trifles make perfection & perfection is no trifle (Ben Franklin)
Your signature is a sign of a job completed, autograph your work with excellence
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 06-16-2008, 04:25 PM
Aggie05 is starting off with a positive reputation.
Whats the next suspect to check regarding EGR problems?
__________________
92 Ranger 2.3 ltr stick shift.
03 Nissan 350z
  #18 (permalink)
Old 06-18-2008, 09:54 AM
still need help....
Im hoping i have not got any responces due to server lag. Dont fail me FTE.
__________________
03 Nissan 350z
  #19 (permalink)
Old 06-18-2008, 10:26 AM
still need help....
Im hoping i have not got any responses due to server lag. Dont fail me FTE.
__________________
03 Nissan 350z
  #20 (permalink)
Old 06-18-2008, 12:59 PM
Well where are you on All the things to check, listed on page one????
On second thought about pulling the B- battery cable, I believe I'd do it for 20 min. or more, so the computer can begin to relearn the things it needs too, with the new parts you've replaced so far.
Let us know where you are on the page one "Do/Check" list.
__________________
  #21 (permalink)
Old 06-18-2008, 02:06 PM
Rockledge's Avatar
Rockledge has a great reputation on FTE.Rockledge has a great reputation on FTE.Rockledge has a great reputation on FTE.Rockledge has a great reputation on FTE.
There is a good explanation (including diagnosing and testing) of the Ford DPFE/EGR system in the following tech articles:
http://www.tomco-inc.com/Tech_Tips/ttt33.pdf
http://www.tomco-inc.com/Tech_Tips/ttt34.pdf
http://www.tomco-inc.com/Tech_Tips/ttt35.pdf
http://www.tomco-inc.com/Tech_Tips/ttt36.pdf
__________________
'98 Ranger XLT 4x4 (4.0L)
'97 Taurus GL (3.0L Vulcan)
'94 Taurus SHO (MTX)
Ford Pics
  #22 (permalink)
Old 06-18-2008, 05:08 PM
OKay i have checked all vacuum lines and replaced the EVP.
IM guessing my truck has the PFE not the DPFE sensor but I am not 100%. I say that b/c i have not seen anything that resembles the DPFE. THere is a switch looking thing mounted on the passenger side engine bay near the heater hoses that has 1 red and 1 green tube going to the EGR/TB i think. Is that the PFE mechanism? Im guessing the sensor that i replaced didnt fix anything b/c the engine still has a minor but noticeable ruff idle and is still throwing 13,32,33 codes.
I am still reading through the PDFs that rock posted but dont understand all of them 100%.
Can anyone tell me if my truck came with the DPFE or PFE sensor? 92 ranger 2.3ltr ?
__________________
03 Nissan 350z
  #23 (permalink)
Old 06-18-2008, 06:58 PM
Ok good feedback on the vacuum line checks.
Did this vacuum line check also include the PCV valve & it's hoses????
What does the underhood, atop the radiator support, VECI label say about your EGR system?????
__________________
  #24 (permalink)
Old 06-19-2008, 10:30 AM
[IMG][/IMG]
Yes i replaced the PCV and inspected pcv hose. i know you cant read the diagram in the picture but it shows how the system is routed. The red and green hoses arre connected from the sol V one goes to the main vac port other one to the EGR. Shows a vac line going from the a/cv pv near the front of vehicle to the vac port. last hose goes from the vac port to the fpr which looks like a little vacuum diaphragm thing.
__________________
03 Nissan 350z
  #25 (permalink)
Old 06-19-2008, 09:44 PM
Per paw paws request i went ahead and pulled battery cable for few hours then reattached and pulled koeo codes. I got 15-12-51, 15 is failure in electronic control assebmly (going to need help on that one) 12 is system cannot raise engine speed above normal idle which makes since b/c the idle has been out of wack, and 51 is the Engine coolant temp sensor is too high. I replaced that sensor a few weeks ago.
GOOD NEWS NO MORE EGR codes! Still need help on other codes. Even though this truck runs okay i like things to work like they should so i want to be able to drive this thing with 0 codes, god willing. TALK to me FTE im listening!
__________________
03 Nissan 350z
  #26 (permalink)
Old 06-20-2008, 10:33 AM
any ideas on codes?
__________________
03 Nissan 350z
  #27 (permalink)
Old 06-20-2008, 12:30 PM
OK, good to hear you seem to have put the computers EGR system complaints to bed!!!!
But the computer is still complaining about it's ECT sensor, (code 51) saying the sensor, or wiring is open circuit, or indicates -40F!!!!
So breakout your multimeter & check the new ECT sensors resistance to ground & it's electrical connector & wiring.
The computer needs it's engine temp sensors input to be correct in order to know when the engine is warmed up, so it can begin to use the O2 sensors feedback input to adjust fuel trim & bring the EGR system online, ect.
Without the ECT's input, the compuer will think the engine is cold & enrich the the fuel trim & poor mpg was one of your origional complaints on page 1.
The computer ROM or KAM memory failure code (15) & cant' control high rpm code (12), I'd set aside for now, until you get the ECT problem squared away, so the computer isn't confused about the engines true operating temp.
__________________
  #28 (permalink)
Old 06-27-2008, 06:09 PM
OKay Pawpaw i tested ECT and came up with these results.
Truck temp at 170 the voltage going to computer was ~.24-.26 which seems to low
Truck temp at 173 the resistance was 3.7 which seems close.
What now? This was just replaced a few months ago. Bought at auto zone so could easily be bad but what do you think?
Thx
These temps posted was after i drove from work about 25 miles and then left truck idling. I replaced thermostat with new one and my temps are still to low.
I checked old thermostat today and it seem to work fine, started opening up around 195 and completely open by 207 degrees.
__________________
03 Nissan 350z
  #29 (permalink)
Old 06-28-2008, 12:39 AM
Thx
At KOEO, with the ECT wire disconnected, what REF voltage do you measure at the wire connector????
With it's lead disconnected & at room temp, of say 75-80 F, what does the ECT resistance measure to ground?????
The computer thinks the engine is cold (-40), so it's seeing a high resistance, or a messed up return ref voltage.
Sounds like the old thermostat is opening ok, but the operating engine temps you posted are low, if the new thermostat you have is a 195 F & it's working properly & you measured engine temp while it was running, or immediately after shut down.
So it kinda sounds like the new thermostat is acting up!!!! Is it a OEM, or aftermarket one.
Seems to me I rmember you saying you were gont to install a OEM one????
__________________
  #30 (permalink)
Old 06-28-2008, 07:44 AM
Here is a link to a more detailed ECT temp/resistance profile. Ford Fuel Injection Engine Coolant Temperature Sensor (ECT)
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
