Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 06-05-2008, 01:29 PM
GoCamping's Avatar
GoCamping GoCamping is offline
Garage is empty, add now
GoCamping is gaining momentum as a positive member of FTE.GoCamping is gaining momentum as a positive member of FTE.
Question Biodiesel transfer and storage
Hey guys,
Been fooling around with bio-d myself on and off and finally found out about and joined a local, established co-op. Much easier when you can work together instead of on your own!
Anyway, I would like to work it out so I can come by and get my "allowance" once a month and store the fuel at home. (All I'm doing now is limited by using diesel cans). What do you guys use for transferring and storing? I also considered an aux fuel tank and just keep the fuel in the truck bed but they are $$$ not to mention the theft side of things...
I thought about two 55gal drums - one in the truck and one at home; pump into drum at the co-op, then pump out into the drum at home. Any recommendations on a good pump setup? Don't want to spend too much but not el cheapo either...
Thanks!
__________________
2000 Ford F250 7.3PSD CC SB 2WD Auto. Mods: AIS; CCV mod; Wicked Wheel; Walker BTM; DP-Tuner 40hp PCM flash; ISSPRO EGT / Boost / Trans / Water; Coolant filter; Trans filter; Ride-Rite airbags, Rancho RS9000XL, 50 cent mod, 05+ headlights and grill, front hitch, added fogs and HIDs, LED swaps, nagging desire to go RVing...
2008 Crossroads Cruiser CF32BL 5th wheel; 2006 Subaru Outback 2.5XT; 2000 Audi A4 1.8T APR chipped!
  #2 (permalink)
Old 06-06-2008, 05:40 PM
monsterbaby's Avatar
monsterbaby monsterbaby is offline
1967 Ford Galaxie
monsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputation
for a pump I actually use one like this
Tuthill Hand Fuel Pump — 2in. NPT, Model# FR152NT | Barrel + Hand Pumps | Northern Tool + Equipment
I have two of them one for bio, and one for my race gas have had both of them for going on 4yrs now and never had any issues with either one and pumped a lot of fuel with them. Price isn't to bad either. If you want electric pump you are really going to jump up in price.
Personally I would just use a couple 55 gallon drums.
__________________
Rob
Learn from your parents mistakes.......... Use birth control
  #3 (permalink)
Old 06-09-2008, 02:28 PM
TXHillCountry's Avatar
TXHillCountry TXHillCountry is offline
2003 Ford F-250
TXHillCountry is starting off with a positive reputation.
Quote:
And I'd use 55 plastic drums, specifically for the storage.
We get them down here for $15 a barrel if they were "food grade", ie..they came with juices, soft drinks, etc in them, or $10 a barrel for the ones that came with liquid soaps for places like car washes.
TX
__________________
2003 F250 6.0 PSD FX4 King Ranch Crew Cab Shortbed -> STOLEN, STRIPPED, TOTALED
Banks Six Gun with PDA Banks Monster Exhaust Banks Intake EGR Delete Kit ARP Headstuds 2005 Grille 305/70/16 BFGoodrich ATKO tires Westin Bull Nose with 6" KC Slimlights ICON Vehicle Dynamics Leveling Kit
  #4 (permalink)
Old 06-09-2008, 03:28 PM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
TX
Uhmmmm
I vaguely recall something about using plastic to store BD.
I cannot be sure but check it out before you commit.
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
  #5 (permalink)
Old 06-09-2008, 04:01 PM
2003 Ford F-250
Quote:
Originally Posted by Phydeaux88 View Post
Uhmmmm
You might be thinking of using plastic (HDPE) for the reactor drum, which can get soft when heated. As far as storage, they are excellent vessels (provided you use the right ones.)
Here's a brief spec outline for a good plastic storage vessel.....
- HDPE/Plastic drums are excellent for storing BioDiesel. Many HDPE drums are used for food services and environmental services use. I've seen, used and received containers that had held soap, apple juice, cooking oil, Diet Dr. Pepper, vinegar, and Soy Sauce. Once it's rinsed out, an HDPE drum is great for storage.
Most good quality drums are UN rated. For the specific type that you need for good BioDiesel storage, fellow BioDiesel enthusiasts have recommended the following specifications:
Plastic/HDPE drum:
Minimum specficiation of:
- 1H1 (Plastic Drum, closed)
- Y1.0, X1.0, or higher (X or Y designation is for the packing group performance standard code. You want X or Y as the code. The numeric designates the maximum specific gravity of the liquid you are storing. BioDiesel averages .85-.88 for it's specific gravity.)
- 100 (hydrostatic pressure rating in kPa or PSI)
As an example - you'll see a code of: 1H1/X1.8/150/05
This translates out to a closed plastic drum, Packing Group 1, 2 or 3 with a liquid SG maximum of 1.8, 150 PSI, built in 2005.
__________________
  #6 (permalink)
Old 06-09-2008, 05:27 PM
Phydeaux88's Avatar
It is entirely possible that the comment about plastic drums I remember so vaguely was about using them for processor
Thanks for the specs on drums
__________________
  #7 (permalink)
Old 06-16-2008, 08:36 PM
GoCamping's Avatar
Wow great info about the drums - thanks guys. I think it will be a hand pump like described above and some 55gal drums. When I had my own reactor setup I found plenty plastic ones available so hopefully that's still the case...
__________________
  #8 (permalink)
Old 06-17-2008, 07:45 AM
aaronsteinblock aaronsteinblock is offline
aaronsteinblock is starting off with a positive reputation.
The state paid us $3,000 to put a 600gal tank on our property. It was part of the Alternative Fuel Tax Package.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
