WVO has Auto Trans Fluid in it...QUESTION? - Ford Truck Enthusiasts Forums
Old 06-05-2008, 11:33 AM
MLCRI$I$ II's Avatar
MLCRI$I$ II MLCRI$I$ II is offline
MLCRI$I$ II is starting off with a positive reputation.
While experimenting with a new electric pump which will be used for my processer set-up, I attempted to transfer some WVO I collected from one container to another. The pump needed to be primed several times before the actual transfer took place. I did not have a separate container set aside with WVO for the priming and used new auto trans fluid to prime the pump. I used about 2/3 QT and now have AT fluid mixed with my WVO.
Any concerns I need to be aware of when tritating, processing, etc? The AT fluid mixed with the WVO and did not separate. Thanks for your input.
Ernie
95 powerstroke mechanical pump/check valve/ fuel line question. Melody Guzman Bio-diesel, Propane & Alternative Diesel Engine Fuels 7 12-22-2012 09:38 PM
wvo system hookup naturescape Bio-diesel, Propane & Alternative Diesel Engine Fuels 1 11-10-2010 09:04 AM
WVO ideas and questions dzzavid Bio-diesel, Propane & Alternative Diesel Engine Fuels 2 03-06-2008 09:04 AM
The pros and cons of homemade biodiesel vs wvo. derherr65 Bio-diesel, Propane & Alternative Diesel Engine Fuels 66 04-23-2007 09:23 AM
WVO and Dino mix csmtolle Bio-diesel, Propane & Alternative Diesel Engine Fuels 9 07-06-2006 10:13 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
