Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Electrical Systems/Wiring
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-05-2008, 11:00 AM
baddmove's Avatar
baddmove is starting off with a positive reputation.
Wierd window prob. on BII
hey all..i have a 89' 2.9L , a/t, edie bauer, BII i just got from a friend and it has an issue with the passenger side electric window.i can roll it up/down from the driver side..but can't from the passenger side unless the door is open.. if i pull on the wire and close the door as far as i can, it will go up/down. i can see the wire runs inside the fender well,do i need to take off the fender and make sure it is hooked up/connected right?
thanx...
__________________
89 EB bronco II 2.9
A/T A/C - daily driver
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-05-2008, 01:31 PM
Franklin2's Avatar
Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.
The wire is probably damaged internally from it bending when the door is opened/shut. If you pull the door harness wiring out, take each wire and hold it on one end with one hand, and take your thumb and finger from the other hand and pinch the same wire, and then start sliding down the wire while you are pinching it pretty hard. If you get to a spot where the wire feels lumpy, or it stretches, then that's the area where the copper inside has broken.
__________________
Dave F
1989 F250 XLT Diesel
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
