Cowl Removal Question F-250 - Ford Truck Enthusiasts Forums
Old 06-04-2008, 06:59 PM
cowboy117 cowboy117 is offline
cowboy117 is starting off with a positive reputation.
I need to replace a windshield washer jet on my 1992 F-250 King Cab[drivers side] and have all of the screws out of the cowl and can move it around good on the drivers side but it's tight on the passenger side and i can't get my hand in there.How do i remove the antenna [at which end] so the cowl will have enough clearance for my hand to get in there to remove and replace the jet?Thanks.Any tips to make the job go well will be appreciated.Also,when reinstalling the rubber cowl seal should i use silicone or weatherstrip adhesive on it and in the screw holes?I'm concerned that it could channel water inside.
Old 06-04-2008, 07:24 PM
lostin90s lostin90s is offline
lostin90s is starting off with a positive reputation.
Get a friend To help (I have done it by my self. ). Mark the hood hinge. Not the one with spring . Then remove bolts From the one with no spring .(friend holds hood ) Once bolt r out
u Can let hood rotate (Spring hinges still up ) Down to core support . The cowl will come right up then For allot more room. (Antenna is only thing holding it now.
Old 06-05-2008, 02:41 PM
jjstanza jjstanza is offline
jjstanza is starting off with a positive reputation.
X2 on the hood. I tried it without removing/moving hood and I scratched the crap out of the cowl panel.
Old 06-10-2008, 10:15 PM
Got it!Thanks for the help!
Old 06-10-2008, 10:22 PM
icrman icrman is offline
icrman is starting off with a positive reputation.
So is the antenna attached to the cowl panel? And it comes out with it??
88 ford cowl 88_F0RD 1987 - 1996 F150 & Larger F-Series Trucks 1 05-11-2016 09:04 PM
84 Ford F250 Cowling removal FilmCarp Paint & Bodywork 5 08-16-2014 11:05 PM
cowl vent removal abe 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 06-10-2014 12:53 AM
Windshield Cowl air1jpg 2004 - 2008 F150 10 12-10-2012 09:13 PM
removing the cowl JeremiahM 1973 - 1979 F-100 & Larger F-Series Trucks 1 07-09-2011 03:17 PM
Tags
94, cowl, f250, removal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
