Trans Go kit which one?
Old 06-03-2008, 07:51 PM
Flea's Avatar
Flea
Flea is offline
Here are the options I have found.
E4OD-4R100 Valve body kits: Bulkpart transmission parts
I am wanting to start pulling about 10K pounds and want to protect my tranny.
Any ideas? I think the first one is the best?
Valve body kits
<input name="Action" value="" type="hidden"><input name="Product_Code" value="" type="hidden"><input name="Quantity" value="" type="hidden"><input name="Screen" value="CTGY" type="hidden"><input name="Attributes" value="Yes" type="hidden"><input name="Store_Code" value="2" type="hidden"><input name="Category_Code" value="E4OD-4R100vbkits" type="hidden"><input name="Offset" value="" type="hidden"><input name="Order" value="1" type="hidden"><input name="CTGYAction" value="" type="hidden"><input name="Previous_Stack_Depth" value="" type="hidden"><input name="ProductCount" value="9" type="hidden"><table border="0" cellpadding="2" cellspacing="0"> <tbody><tr> <td align="left" bgcolor="#000080" valign="middle" width="100%"> [***************] Name [/COLOR] </td> <td align="left" bgcolor="#000080" valign="middle"> [***************] Image [/COLOR] </td> <td align="right" bgcolor="#000080" valign="middle"> [***************] Price [/COLOR] </td> <td align="right" bgcolor="#000080" valign="middle"> </td> <td align="left" bgcolor="#000080" valign="middle">
</td> </tr> <form name="CTGYProducts" method="post" action="http://www.bulkpart.com/Merchant2/merchant.mvc?"></form>******** language="JavaScript"> <!-- function SubmitAddOne(Product_Code) { document.CTGYProducts.elements[ 'Action' ].value = 'ADPR'; document.CTGYProducts.elements[ 'CTGYAction' ].value = 'addone'; document.CTGYProducts.elements[ 'Product_Code' ].value = Product_Code; document.CTGYProducts.submit(); } function SubmitAddAll() { document.CTGYProducts.elements[ 'Action' ].value = 'ADPR'; document.CTGYProducts.elements[ 'CTGYAction' ].value = 'addall'; document.CTGYProducts.submit(); } function SubmitAdd(Product_Code) { document.CTGYProducts.elements[ 'Action' ].value = 'ADPR'; document.CTGYProducts.elements[ 'CTGYAction' ].value = 'addtobasket'; document.CTGYProducts.elements[ 'Product_Code' ].value = Product_Code; document.CTGYProducts.submit(); } function SubmitBuyOne(Product_Code) { document.CTGYProducts.elements[ 'Action' ].value = 'ADPR'; document.CTGYProducts.elements[ 'CTGYAction' ].value = 'buy1now'; document.CTGYProducts.elements[ 'Screen' ].value = 'LOGN'; document.CTGYProducts.elements[ 'Order' ].value= 1; document.CTGYProducts.elements[ 'Product_Code' ].value = Product_Code; document.CTGYProducts.submit(); } //--> *********> <tr> <td align="left" bgcolor="#ffffff" valign="top"> # T36169E
TransGo Reprogramming Kit E4OD / 4R100 Automatic shift: Heavy loads, Pro-street
*No V.B. gaskets in this kit! E40D-HD2, Automatic shift: Heavy loads, Pro-street and competition. Holds 1st, 2nd, 3rd to any RPM. New Calibration system with broader range adjustment. E4OD 1989-2001 4R100 1989-up Gas & Diesel
Order Valve body gaskets for the year your working on....info->
</td> <td align="left" bgcolor="#ffffff" nowrap="nowrap" valign="top"> </td> <td align="right" bgcolor="#ffffff" nowrap="nowrap" valign="top"> $62.50 </td> <td align="right" bgcolor="#ffffff" valign="middle"> </td> <td align="left" bgcolor="#ffffff" valign="top"> <input value="Add 1" onclick="SubmitAddOne('T36169E')" type="button"><input name="QuantityA_T36169E" value="1" type="hidden"> </td> </tr><tr> <td align="left" bgcolor="#ffffdd" valign="top"> # T36169EA
TransGo Tugger Kit 4R100-HD2 , 1989-2004, 4R100 & E4OD *Updated Kit
The Tugger Kit features the ultimate high load calibration parts for the Ford E4OD and 4R100 transmission. Used with exhaust brake, fixes downhill shift delay.
This kit doubles low and reverse clutch pressure for downhill hauling.
Adjustable shift firmness, more cooling / lubrication and ...info->
</td> <td align="left" bgcolor="#ffffdd" nowrap="nowrap" valign="top">
</td> <td align="right" bgcolor="#ffffdd" nowrap="nowrap" valign="top"> $98.00 </td> <td align="right" bgcolor="#ffffdd" valign="middle"> </td> <td align="left" bgcolor="#ffffdd" valign="top"> <input value="Add 1" onclick="SubmitAddOne('T36169EA')" type="button"><input name="QuantityA_T36169EA" value="1" type="hidden"> </td> </tr><tr> <td align="left" bgcolor="#ffffff" valign="top"> # T36165E
TransGo Shift Kits E4OD / 4R100 *Updated Kit
TransGo # SK E4OD Shift improvement / correction kit 1988-2001 Prevents / corrects / Reduces soft shifts, converter burn up, delayed reverse, pump buzz....info->
</td> <td align="right" bgcolor="#ffffff" nowrap="nowrap" valign="top"> $37.94 </td> <td align="right" bgcolor="#ffffff" valign="middle"> </td> <td align="left" bgcolor="#ffffff" valign="top"> <input value="Add 1" onclick="SubmitAddOne('T36165E')" type="button"><input name="QuantityA_T36165E" value="1" type="hidden"> </td> </tr><tr> <td align="left" bgcolor="#ffffdd" valign="top"> # S86741HDK
Sleeve & Plunger, Line Pressure Modulator , AX4N / E4OD / 4R100
.427 inch valve , Adjustable 1-2 & 2-3 Shift firmness, Restores hydraulic integrity of EPC…. Common vender is Sonnax # 96948-01K...info->
</td> <td align="right" bgcolor="#ffffdd" nowrap="nowrap" valign="top"> $20.84 </td> <td align="right" bgcolor="#ffffdd" valign="middle"> </td> <td align="left" bgcolor="#ffffdd" valign="top"> <input value="Add 1" onclick="SubmitAddOne('S86741HDK')" type="button"><input name="QuantityA_S86741HDK" value="1" type="hidden"> </td> </tr><tr> <td align="left" bgcolor="#ffffff" valign="top"> # S36741GK
Valve & Sleeve, Line Pressure Modulator (.331 inch) , E4OD
Improves 1-2 & 2-3 shift feel …. Common vender is Sonnax # 36948-03K...info->
</td> <td align="right" bgcolor="#ffffff" nowrap="nowrap" valign="top"> $20.84 </td> <td align="right" bgcolor="#ffffff" valign="middle"> </td> <td align="left" bgcolor="#ffffff" valign="top"> <input value="Add 1" onclick="SubmitAddOne('S36741GK')" type="button"><input name="QuantityA_S36741GK" value="1" type="hidden"> </td> </tr><tr> <td align="left" bgcolor="#ffffdd" valign="top"> # S36741GAK
Valve & Sleeve, Line Pressure Modulator (.372 inch) , E4OD
Adjustable 1-2 & 2-3 Shift Firmness, Restores hydraulic integrity of EPC …. Common vender is Sonnax # 36948-05K...info->
</td> <td align="right" bgcolor="#ffffdd" nowrap="nowrap" valign="top"> $20.84 </td> <td align="right" bgcolor="#ffffdd" valign="middle"> </td> <td align="left" bgcolor="#ffffdd" valign="top"> <input value="Add 1" onclick="SubmitAddOne('S36741GAK')" type="button"><input name="QuantityA_S36741GAK" value="1" type="hidden"> </td> </tr><tr> <td align="left" bgcolor="#ffffff" valign="top"> # S36741EK
Valve Kit, Accumulator Regulator , E40D
3-4 Accumulator…. Common vender is Sonnax # 36948-09K...info->
</td> <td align="right" bgcolor="#ffffff" nowrap="nowrap" valign="top"> $10.81 </td> <td align="right" bgcolor="#ffffff" valign="middle"> </td> <td align="left" bgcolor="#ffffff" valign="top"> <input value="Add 1" onclick="SubmitAddOne('S36741EK')" type="button"><input name="QuantityA_S36741EK" value="1" type="hidden"> </td> </tr><tr> <td align="left" bgcolor="#ffffdd" valign="top"> # S36741EAK
1-2 & 2-3 Accumulator …. Common vender is Sonnax # 36948-13K...info->
</td> <td align="right" bgcolor="#ffffdd" nowrap="nowrap" valign="top"> $11.52 </td> <td align="right" bgcolor="#ffffdd" valign="middle"> </td> <td align="left" bgcolor="#ffffdd" valign="top"> <input value="Add 1" onclick="SubmitAddOne('S36741EAK')" type="button"><input name="QuantityA_S36741EAK" value="1" type="hidden"> </td> </tr><tr> <td align="left" bgcolor="#ffffff" valign="top"> # S36165E
Superior SuperiorShift correction package E40D
1989-up To be installed during rebuild! Not a performance type kit...info->
</td></tr></tbody></table>
Old 06-04-2008, 01:11 AM
Joe_D's Avatar
Joe_D
Joe_D is offline
Well I would avoid anything that is going to raise fluid pressure. That said you might want to try the c00nhunterjoe accumulator body mod. It doesn't cost anything but your time and I like what it did for my truck.
See these threads on this subject.
https://www.ford-trucks.com/forums/6...hift-kits.html
https://www.ford-trucks.com/forums/6...-question.html
Old 06-04-2008, 07:25 AM
MADVAN's Avatar
MADVAN
MADVAN is offline
A rise in line can be a good thing. Just dont go nuts with it.
Its like adding pane. Small amount goes a long way.
OP
Really depends on if you are going to pull the pump or not.
Bill
Old 06-06-2008, 02:42 PM
powerstroked162's Avatar
powerstroked162
powerstroked162 is offline
The coon mod..... lol!
Transgo hd2 kit is the way to go, its safe, reliable, and very easy to work. I personally use it in my truck with a few extras from the gents at ATS
Cowboy Steve
Old 06-06-2008, 06:55 PM
NWBronco's Avatar
NWBronco
NWBronco is offline
Roger that. The Tugger kit has been sittin' in my garage for over a year now. Too many projects, not enough time....
Bob
Mr.Watson
1999 to 2016 Super Duty
17
01-18-2020 09:27 PM
aquaman
2004 - 2008 F150
06-28-2012 07:48 PM
Moto Mel
07-21-2010 06:51 AM
Quick Reply: Trans Go kit which one?
