1988 F-250 Stock 460 Engine Specs? - Ford Truck Enthusiasts Forums
Old 06-03-2008, 07:33 PM
MrScharfenberger MrScharfenberger is offline
MrScharfenberger is starting off with a positive reputation.
I recently aquired a 1988 F-250 with a 460. The engine is using a lot of oil and is very tired. I'm going to do a rebuild with some minor modifications. I'd like to know what the stock cam shaft specs are for this model year. Actually I'd like to know all the enging specs. So if there is anybody out there that has a link or just knows all the info let me know please!! You may view my Hot Rod 1974 F-100 at Login . The F-250 is what I'm going to use to trailer the F-100 to the drag strip and back. Thanks in advance!!
Old 06-04-2008, 10:12 AM
desert1dog desert1dog is offline
desert1dog is starting off with a positive reputation.
Camshaft Specifications.
Quote:
I am using an 87 Factory Manual so I know not if the 88 is the same but our Members would know.
Lobe lift: Intake-.252 Exhaust-.278
End Play: .001-.006
Service Limit: .009
Camshaft Journal to Bearing Clearance: .001-.003
If the same as an 87 and you need any specifications e-mail me: desert1dog@earthlink.net
Coolant Capacity, 1988 F-250, 460 Eng. mrplumber 1987 - 1996 F150 & Larger F-Series Trucks 2 02-19-2012 12:30 PM
86 F-150 4.9L cam specs Monte1go 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 01-23-2010 03:31 AM
'74 Factory 302 Specs? Nathan Plemons Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 9 07-01-2009 12:31 PM
Freak the EEC?? MrScharfenberger 1987 - 1996 F150 & Larger F-Series Trucks 4 08-11-2008 03:26 PM
1974 F100 521 C.I.D. Rear Suspension MrScharfenberger 1973 - 1979 F-100 & Larger F-Series Trucks 6 01-26-2007 02:41 PM
Tags
1988, 460, 87, 88, engine, f250, ford, specs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
