Anyone else have probs with Level Kit?
Hey guys,
Its like the title reads....I guess it not huge issue.....but still an issue. I have had my level kit on for the past 1yr 1/2 and have noticed the camber on my wheels is off just touch. Primaely becasue it just puts the CV Joint at such a angle that it's prob not good for the front and I think it may have also caused my tires to wear slightly faster.
My alignment is fine and it not that big of issue but would love to find a way to address this issue before my next set of tires? Anyone sell like a spacer to lower that front differential like 1/2" or any other ideas would be much appreciated. Thanks.
Matt
Matt
What size leveling kit do you have? Maybe you can try a smaller one. You'll have to get a suspension lift if you want to lower the front differential. (It is too close to the driver's side lower control arm pocket. That's the piece that has to be cut off on the kits that are most used... procomp, rancho, rcd, fabtech, rize... etc.) I didn't really have any issues on the 2.5" leveling kit I had. I ran it for about two years and did have a CV boot tear... but not 100% sure it was the leveling kits fault.
Matt
the leveling kit doesn't affect left to right on your alignment. My tires are perfectly aligned and they're wearing great.
are you sure it's the alignment? what type of tire do yo have? and what pressure do you run? I run 44-45 psi on my Wranglers (LT tire). under-inflation could also cause the effect your describing
when i put my leveling kit on and did my alignment at work the camber was off ...but when i adjusted the toe it just went in to factory spec but not by much...but most shop just set the toe and nothing else if it out...now to fix factory camber you have to buy a camber kit from napa so you can adjust it in to spec
Very interested in the Napa Camber kit....Exactly what it do and what would that cost?
Thanks
Matt
what you do is replace the bolt in the upper control arm with new bolts that have egg in like shape washer...now that will let you adjust the upper control arm to get camber and caster..for some odd reason ford doesnt use the stock like gm and dodge
kit prices are like 25-50 dollars
but a good way to know what your aligment is did u get a print out of the new spec?
Thanks for all the info...
Matt
how much you want for it???
Couldn't find the ad....
