92 Explorer 4x4 differential and tranny questions
My dad has a 92 ford explorer 4x4 auto. I was wondering if there are any negitives to using mercon V syn. Or what should I use. The other question I have is what weight differential fluid should I use and how much of each. The Front is Dana 35 ttb, and the rear is Ford 8.8 I believe. Also is it ok to use syn ATF in the T-case as well? Thanks.
__________________
1999.5 F-350 SC SB 4x4 XLT SRW
7.3L PSD / Auto / 3.73 LS
Muffler Delete, 6637 Mod, Zoodad, CCV mod, Stancor GPR mod
Best truck I've ever owned
"It's better to have it, and not need it; than need it, and not have it."
"You can't legislate stupidity"
-Max
