F-250 diesel ran out of fuel - Ford Truck Enthusiasts Forums
Old 06-02-2008, 05:21 PM
duckb52 duckb52 is offline
duckb52 is starting off with a positive reputation.
Ran out of fuel today. Put in 1/2 tank of fuel and now truck won't crank. Turns over like a champ but will not crank. Fuel filter on top is ok and pump seems to be pumping. What should I try first? Thanks for any help.
Old 06-02-2008, 05:37 PM
big poppa's Avatar
big poppa big poppa is offline
big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.
I think by keeping on cranking in spurts you will prime the system again. When it does start, you will see white smoke and very eratic engine idle. Let it idle for a while. Don't crank to long though, you will burn out the starter. Good luck.
Old 06-02-2008, 06:33 PM
I'll give this a try. Thanks for the suggestion!
Old 06-02-2008, 07:24 PM
F350-6's Avatar
F350-6 F350-6 is online now
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Quote:
Yep, do what Mike suggested. You might also want to check you're fuel filter to see if you sucked any trash up in there as you got those last drops of fuel.
Make sure the fuel bowl is full. You can do this by cycling the key a few times without cranking the motor.
Old 06-03-2008, 03:06 AM
Flatdeck's Avatar
Flatdeck Flatdeck is offline
Flatdeck is gaining momentum as a positive member of FTE.Flatdeck is gaining momentum as a positive member of FTE.
Put some diesel in a jerry can and fill your fuel bowl. Then turn the key, wait for the light to go out of course, then crank it. It should start after a little bit. It'll run really rough for a few miles until you get the air out of the system, then it'll smooth out like nothing happened. Uh, it was a friend who ran out, that's how I know this.
Old 06-03-2008, 06:57 AM
Izzy351's Avatar
Izzy351 Izzy351 is offline
Izzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud of
After I did my in-tank mods (fuel lines were completely opened & bowl was emptied), it primed right up after three cycles of the key. And that was with only 6 gallons in the tank from bone dry. I did have the CCK already installed though -- that probably helped quite a bit too. Put the Hutch/Harpoon on your mods to-do list.
Old 06-03-2008, 05:03 PM
Thanks for the suggestions. This site has helped me everytime I visited.
Again, I can't thank you enough.
Old 06-03-2008, 05:15 PM
HKusp's Avatar
HKusp HKusp is offline
HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.
Did it work?
Old 06-03-2008, 06:57 PM
big poppa's Avatar
Well, did that help you??? Also, welcome to FTE.
Old 06-03-2008, 09:00 PM
mudmaker's Avatar
mudmaker mudmaker is offline
mudmaker has a very good reputation on FTE.mudmaker has a very good reputation on FTE.mudmaker has a very good reputation on FTE.
I had a fun experience of running out of fuel last week 5 miles short of Flying J on the interstate (didnt think it was possible to get as bad of mileage as I did on that run!!). Got 5 gallons of fuel in her, cycled the key several times and cranked. She fired once, but wouldnt go. When I went to open the fuel filter a bunch of air came out, closed it back up and she fired up and ran fine after a few minutes of idling.
Old 06-03-2008, 09:14 PM
cookie88's Avatar
cookie88 cookie88 is offline
cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.
Good point Marc. It's nice that we have the capacity to bleed the system on the fly. Comes in handy.
Old 06-03-2008, 09:43 PM
orng1's Avatar
orng1 orng1 is offline
orng1 has a great reputation on FTE.orng1 has a great reputation on FTE.orng1 has a great reputation on FTE.orng1 has a great reputation on FTE.orng1 has a great reputation on FTE.
It's hard to get a diesel started once the system has gone dry. Easiest way is with some engine start spray but not too much, a little will do on a diesel. Once it's running it will fill up the fuel bowl easily on it's own.
Old 06-03-2008, 09:50 PM
cookie88's Avatar
"Negative ghost rider, the pattern is full."
Never use ether on a glow plug equipped diesel. A little WD-40 if you must......no ether.
Cranks but wont run. Please Help 02 F250 7.3l 1999 - 2003 7.3L Power Stroke Diesel 15 05-03-2015 09:59 PM
Starting after running out of fuel redman84 1994.5 - 1997 7.3L Power Stroke Diesel 9 01-01-2014 07:52 PM
Ran out of diesel beeman127 6.0L Power Stroke Diesel 16 06-06-2010 06:56 AM
Fuel up no start Hiflyer746 6.0L Power Stroke Diesel 16 02-08-2009 11:03 PM
2000 f350 ran out of diesel won't start elvia 1999 - 2003 7.3L Power Stroke Diesel 18 08-19-2007 08:49 PM
Tags
1997, 1999, 2001, 73, diesel, erratic, excursion, f250, ford, fuel, idle, out, ran, start, starting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
