You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Does anyone have plans for a dry wash system that they would share? Seems like the most common used is Magnesol. Our processor is a 50 gallon water heater, so should be doing about 35 gallon batches.
thanks
__________________ Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!! 2002 TDI New Beetle - also likes Bio.
I don't really have "plans" but it is much less complicated than water washing.
All you need to do is mix in the magnesol GENTLY ( no pump mixing) for about 30 min, and filter it out, or let it settle overnight, then siphon the bio off the top.
If you remove the excess Methanol first it only needs 1% magnesol by weight. If not it will require 2%.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
i just ordered a bag of magnesol. It took 8 gallons of water to cleanly wash my last 4 gallon batch and I couldn't imagine using water for 40 gallons. my processor is almost complete.
__________________
If the lunch meat called spam became the catchword for a depersonalized email message, then social networking should be known as soylent green!
I started waterwashing at first, but it didn't take me long to switch to Magnesol! Waterwashing is a PITA...........Buy the testing I've had done, Magnesol produces a much better quality fuel.
__________________
__________________
95 F350 SC PSD Auto 4.10 Pro-Tech Aluminum Flatbed with side boxes AutoMeter Transmission and Boost gauges 6637 Filter mod 160K miles B&M 24K Transmission cooler Diamond Eye stainless steel exhaust 2 tank WVO
I use a diaphragm pump to force the bio/Magnesol mix through the filter setup, but haven't tried it for mixing since I have a 75 gallon mechanical mix tank that I use for my processor. It was set up so all I had to do was flip a switch on the control panel and I could use it for the processor or mixing the magnesol.
I think it would work, just haven't tried it out
__________________
