Help! How do you replace a subwoofer in a '98 Expedition E.B.?
Old 11-04-2002, 12:36 PM
Qman_1's Avatar
Qman_1
Qman_1 is offline
Hi,
I have blown the subwoofer on my '98 Expedition. I have removed the panel cover and all the screws on the speaker, but I cannot pull it out! Something is holding it back. I can spin it around, but it will not come out. Can anyone tell me the procedure to take it out and repleace it?
Thanks!!
Old 11-05-2002, 08:20 PM
optikal illushun's Avatar
optikal illushun
optikal illushun is offline
Old 06-09-2003, 03:39 PM
AKASarin's Avatar
AKASarin
AKASarin is offline
has anyone figured this out yet, i am having the same problem.
Old 06-21-2003, 03:01 PM
cm450e's Avatar
cm450e
cm450e is offline
The subwoofer is held in place by the screws around the edge and one lare screw through the rear of the enclosure. To remove the subwoofer, you need to remove the entire enclosure (holding the amp and sub). To do this, you need to remove the interior panel to access the three bolts holding in the enclosure. Hope this helps. It took me quite a while to figure it out. Then, I discovered that there are very few places that sell an 8" 2-ohm sub to replace the OEM onw with. Ford will not sell only the sub. They want to sell the entire enclosure, amp, and sub (about $425). There are some aftermarket subs, but you need to search. I called the Ford parts guy and he gave me the number of a shop in town that will sell just the sub. Good luck.
Old 06-22-2003, 08:29 PM
PrPlayboy's Avatar
PrPlayboy
PrPlayboy is offline
Yeah that screw in the back had me too. I didnt blow my sub but I removed it to see what I can do for an upgrade. I was thinking of putting a better 8" in there and running an aftermarket amp and use it for mid bass. I am going to see about posibly making some door pods for mid bass.
natsoundup
70
01-07-2015 03:14 PM
stache2010
2009 - 2014 F150
06-18-2014 05:45 PM
dr cabela
1997-2006 Expedition & Navigator
10-18-2013 11:26 AM
guitar4him
28
08-06-2013 08:22 AM
jfaaborg
04-08-2005 12:24 PM
Quick Reply: Help! How do you replace a subwoofer in a '98 Expedition E.B.?
