Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1947 and Older Ford Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-01-2008, 11:05 PM
Barnfresh41 is starting off with a positive reputation.
Rear axle question
Hi,
We have a 41 1/2 ton and as most of you guys probably know it is a tight fit with a more modern open driveline rear axle. We are in the process of putting a 47 flathead with t-5 and need an open driveline rear end. We picked up a 88 ford truck rear end at a local junkyard, got it home and realized it might be a little bit too wide. We would like to keep the ford 5 1/2 inch bolt pattern. Just wondering what you guys use. Thanks
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-01-2008, 11:08 PM
3Mike6 is gaining momentum as a positive member of FTE.3Mike6 is gaining momentum as a positive member of FTE.
Look for a Bronco rear or an explorer rear...should fit under nicely and keep the 5 on 5.5 pattern
__________________
  #3 (permalink)
Old 06-01-2008, 11:23 PM
Thanks for the reply however the 88 truck is the same as the the bronco about 57 inches backing plate to backing plate (Stock is about 51 inches). The explore on the other hand will fit perfect but the bolt but I believe the bolt pattern is smaller.
  #4 (permalink)
Old 06-02-2008, 12:44 AM
The early Bronco's (maybe called Bronco II's?) were 57 inches WMS to WMS (assuming 3 inch drums would be what you want)...you might be thinking the newer full sized ones?
I thought my 94 explorer had 5 on 5.5" ? But it's been gone for years, maybe I'm mistaken.
__________________
  #5 (permalink)
Old 06-11-2008, 07:11 AM
41inWV's Avatar
41inWV is gaining momentum as a positive member of FTE.
Barnfresh
In my case, on my '41 1/2 ton I'm using a ford 8" out of a '79 Granada. Yes it does change the bolt pattern to 5 on 4 1/2, but I had new wheels made anyway, so that didn't matter to me. I suppose you could run wheel adapters to accomodate the difference in bolt pattern. Not the best solution, but workable.
__________________
Steve
WV Chapter Member
1941 Ford 1/2 Ton Flathead - FTE 'Ride of the Week' 10/28-11/02 2008
1934 Chebby Sedan
  #6 (permalink)
Old 06-11-2008, 11:37 AM
46yblock is starting off with a positive reputation.
I have the same rearend as 41VW, an 8 inch out of an '80 Granada. Also using the '80 drum brakes. It requires a very small backset on wheels, meaning full reverse, to clear the '46 bed. '41 bed is narrower though I think.
__________________
1946 1/2 ton with 305 cu in Y-block
1990 Ranger 4WD
  #7 (permalink)
Old 06-21-2008, 08:28 AM
41inWV's Avatar
Here's my '41 with the bed back on the frame, the '80 Granada rear 8" axle and drum brake setup. Those are 15 X 8 rear wheels I had made with a 3" backset, wearing 255 diamondback rubber.
Then here it is with the fender in place, we need to length the rear fender brace an inch and a half, but it works !
__________________
Steve
WV Chapter Member
1934 Chebby Sedan
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
