Go Back   Ford Truck Enthusiasts Forums > General > Projects
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Projects Share with other members the details about your project truck or SUV. Old or new, gas or diesel, its all welcome here!
  #1 (permalink)
Old 06-01-2008, 05:32 PM
SuperSnake's Avatar
SuperSnake SuperSnake is offline
Garage is empty, add now
SuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to behold
Started my F 250 Project.
Well I got started on my F250 today. After a lot of sanding I found a lot of bond,so I'm going to sand and prime the whole truck to see what needs replaced.Looks like I will need to find another bed or start buying new bed parts and build a new one unless someone can tell me if this bed can be saved after I finish sanding it.
  #2 (permalink)
Old 06-01-2008, 05:33 PM
SuperSnake's Avatar
More pictures.
  #3 (permalink)
Old 06-01-2008, 05:39 PM
khadma's Avatar
khadma khadma is offline
Carpenter Local 745
1966 Too much Tools
khadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud of
Are you trying to make me jealous?
Do you have more pictures of the truck?
I really miss having a Dentside truck, maybe I can find one around here for a reasonable price one day.
I am sure I have to finish all my other projects first.
Keep up the good work Reb!
__________________
Darren
Join the Hawai'i chapter *HERE*
  #4 (permalink)
Old 06-01-2008, 05:47 PM
SuperSnake's Avatar
Yeah I got more pictures. I'll pm you a link to my photobucket.
I hope it turns out good some one put a lot of bondo and didn't finish it.Looks like they used house paint on it too. I hope I don't have to replace the bed.
Thanks for the encouragement Darren.
  #5 (permalink)
Old 06-01-2008, 05:55 PM
khadma's Avatar
Carpenter Local 745
1966 Too much Tools
Link did not work, maybe try adding some in an FTE gallery too!
It is great that you don't have to replace the bed, now you can put money elsewhere on the truck.
__________________
Darren
  #6 (permalink)
Old 06-01-2008, 11:42 PM
Bill W's Avatar
Bill W Bill W is offline
1963 Ford F-250
My Garage
Bill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputation
Dosen't look too Bad, How are you removing the Paint? By hand?
  #7 (permalink)
Old 06-02-2008, 01:08 PM
SuperSnake's Avatar
Quote:
I'm using a cheap Black&Decker 20.00 sander from Wal Mart with 60,100,180 grit sandpaper along with rattlecan primer from Wal Mart too.
I know it's not the proper way to do it,but there is so many layers of paint all in white with house paint being the last layer. I am trying to find out how much bondo and rust is in the bed so I have a idea on how and what I need to repair it properly.
  #8 (permalink)
Old 06-02-2008, 09:44 PM
Boss9F100's Avatar
Boss9F100 Boss9F100 is offline
Boss9F100 has a good reputation on FTE.Boss9F100 has a good reputation on FTE.Boss9F100 has a good reputation on FTE.
I can give you a few pointers if you need.
To strip the bondo and paint just use Aircraft Paint remover as it will take both off. Best method is to get a squeeze bottle (that will handle the paint remover) then just let it run until it bubbles. On thick bondo you may need more than one coat. You can also brush it on (thick as possible) From what I have seen it should be easily fixable. Post more pics.. forgot to take note where you are located?
  #9 (permalink)
Old 06-03-2008, 12:19 PM
SuperSnake's Avatar
Thanks Bosss9F100 that will help. I might order a new side for it.
  #10 (permalink)
Old 06-03-2008, 03:07 PM
Boss9F100's Avatar
remember too that usually a side replacement can be more work that repairing what you have. do you have better pics of side in question?
  #11 (permalink)
Old 06-03-2008, 05:46 PM
SuperSnake's Avatar
Not yet I'm trying to get the whole side sanded and primer the only reason I'm doing the primer is to keep the bare metal from rusting. When I get all the bondo out I will take more pictures.
  #12 (permalink)
Old 06-03-2008, 08:54 PM
just-n-time's Avatar
just-n-time just-n-time is offline
just-n-time is starting off with a positive reputation.
thats how I did mine reb,used the air craft paint remover three cans to do the bed ps dont scrape it and throw it away,after you scrape it put it on the top rails it still has more working power in it. use a plastic cover and it will work longer with out drying out. JNT oh yes you can get the stuff at waly world.
  #13 (permalink)
Old 06-04-2008, 11:05 PM
SuperSnake's Avatar
What kind of plastic? Will saran wrap work?
  #14 (permalink)
Old 06-05-2008, 03:58 PM
ibleedblue1385's Avatar
ibleedblue1385 ibleedblue1385 is offline
ibleedblue1385 has a very good reputation on FTE.ibleedblue1385 has a very good reputation on FTE.ibleedblue1385 has a very good reputation on FTE.
I'm liking this...keep up the good work.
Oh, and post as many pics as possible!
__________________
~Jesse~
78' Bronco
95' F350
  #15 (permalink)
Old 06-12-2008, 12:26 PM
SuperSnake's Avatar
This project is over. I sold my 76
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
