Max tire size for stock 06 f150 4x4
Old 06-10-2008, 01:42 PM
BrianFX4's Avatar
BrianFX4
BrianFX4 is offline
Don't ask me I seem to be the only one that has rubbing issues hahaha.
I have aftermarket rims that are 8.5" wide.
Old 06-10-2008, 05:07 PM
Tylus's Avatar
Tylus
Tylus is online now
MMNC (SS)(Ret)
it just depends on how aggressive the tire is. a 33 or 35x12.5 WILL NOT RUB in the A/T tire. some M/T's do, and some don't.
since Brian's tire is 1" wider than stock, that means ~1/2 of the tire is closer to everything else than a OEM wheel
any good tire shop will let you mount up a tire and test it out. have them mounted and take a test drive
Old 06-16-2008, 06:52 PM
Muddedprairie's Avatar
Muddedprairie
Muddedprairie is offline
Hello New here but not to fords.. In responce to the tires i just ordered 35/12.5/18 Nitto mud grapplers I also have a 2.5 inch leveling kit and i'm having a 3-inch body lift installed as well. I'm going to run the factory rims as well.. Anyone eles with these tires and if so will i have problems?
Mark
Old 10-25-2008, 09:57 AM
badwolf's Avatar
badwolf
badwolf is offline
hey i have a 05 ford f150 fx4 with stock rims will the pro comp extreme all terrians fit on my stock truck. i dont have any leveling kit or lift. I just want a bigger tire than stock. how much will these tires rub
Old 10-25-2008, 11:02 AM
Matt983's Avatar
Matt983
Matt983 is offline
depends on how big you want to go, you should fit 33"s no problem 35"s will require to you level the front of the truck a couple of inchs. Welcome to the site theres plenty of helpful people and info on here!
Old 10-25-2008, 01:31 PM
badwolf's Avatar
badwolf
badwolf is offline
sorry the tires i'm looking at are 305/65r18s pro comp extreme all terrians.
Old 10-25-2008, 07:47 PM
rplatt56's Avatar
rplatt56
rplatt56 is offline
i have a 2" level on my wifes truck and fit 295/70/17s on the factory rims with no problem at all. These rims equate to about 33.4". I could probably went with 305s with no problem at all
Old 03-25-2014, 08:54 PM
JTsLariat4x4's Avatar
JTsLariat4x4
JTsLariat4x4 is offline
I installed a pro comp leveling kit on my 06, with American Racing wheels and Pro Comp AT 325/65/18 I had no rubbing. The 18 x 9 AR wheels were ordered to keep the tires in the stock location in the wheel well. Almost 5 years later and now with 35x12.50x 18 Mud Grapplers, it rubs the sway bar in full lock. I have noticed that the stop lug on the lower control arm is now completely worn off on both sides. I really don't think it would rub at all if I replaced the control arms.
bojackhorseman
2015 - 2020 F150
33
06-10-2017 04:22 PM
Leovardo
2017+ Super Duty
03-22-2017 08:29 PM
Adesros
2015 - 2020 F150
28
03-03-2017 07:22 AM
james oden
1999 to 2016 Super Duty
03-28-2016 09:22 PM
sljim
2009 - 2014 F150
05-06-2009 04:43 PM
Quick Reply: Max tire size for stock 06 f150 4x4
