95 F150 engine swap 5.0 to 5.8L? - Ford Truck Enthusiasts Forums
Old 06-01-2008, 11:12 AM
mstngmikegt's Avatar
mstngmikegt mstngmikegt is offline
mstngmikegt is starting off with a positive reputation.
Hi all,
I have a 95 F150 4X4 5.0L, 4R70W combo. Motor runs good, but getting sense that lower is getting loose. Thinking of swapping a 96 5.8 in. At first, thought no way with that tranny cause different firing order than 5.0, but have heard that those 5.0's use the 351 firing order like my Mustang does so, if that is the case, thinking now computer would work fine. Haven't gotten around to verifying firing order, but if same, what other issues would prevent me from doing this swap? My thinking is that swap really shouldn't hurt MPG (I rarely haul heavy or tow with it anyway..commuter/winter snow crawler service) and the extra torque would be nice.
Otherwise, if the swap won't work, any thoughts on cam choice, heads, etc for the 302 if I pull it and do a freshen up rebuild on it. Oil pressure is good, virtually NO oil usage (or anything else for that matter except lots of gas of course) and truck has 140K on it. Not looking for a big HP bump (got the Mustang for fun) just a decent increase in torque without killing mileage. Thanks all for your advice.
Old 06-01-2008, 11:17 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
If you want more TQ put the 5.8 in, there's nothing you can do to the 5.0 that will give it the 75-100ft/lbs advantage 50 cubic inches provides. If your truck is mass air then the biggest issue you will have is obtaining a flexplate to match the 5.8/4R70W combo. The 5.8 will drink more fuel around town though, that's just the way it is.
Old 06-01-2008, 02:17 PM
Been researching...looks like flexplate is the issue. Have seen stuff about using a Cr Vic one, etc. It looks like stock one for 5.0 (Ford PN E2AZ-6375-A) is used for either AOD or AOD-E trans so I don't understand why stock one from the 96 5.8 (D1ZZ-6375-A) wouldn't work for either trans too? Truck motor came from had an AOD in it. Keep reading about trashing the trans using the wrong set up, so gonna get this right before I start...can't afford to ruin the trans screwing around guessing. Someone has to have done this swap successfully along the way? HELP?!
Old 06-01-2008, 05:03 PM
cjg1999 cjg1999 is offline
cjg1999 is starting off with a positive reputation.
your 95 5.0L has the same firing order as a 5.8L and mustangs. a new cam started inthe 5.0L in 94 which was the same one as the 5.8L. as for the tranny, E4OD is stronger and is also computer controlled.
5.8/E4OD MAF EEC-IV computers robprime Computer Chips & Tuners 13 04-23-2016 07:52 AM
'95 5.0L swap for a '92 5.8L? Fungus232 1987 - 1996 F150 & Larger F-Series Trucks 13 05-12-2015 10:55 PM
95 F150 H.O. swap question Muddydan 1987 - 1996 F150 & Larger F-Series Trucks 0 09-17-2011 11:13 PM
Use 5.0/E4OD MAF EEC-IV to run 5.8/E4OD? robprime Engine Swaps 2 05-21-2009 09:20 PM
96 F150 5.0L CAM SWAP with 5.8L Lightning? LX96TBIRD Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 3 07-01-2000 06:32 PM
Tags
1995, 50, 5058, 58, 58l, 94, 95, 96, bu, engine, f150, ford, swap, swapping, swaps
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
