June Catch all thread
#124
Morning everyone!!
Hey randy, Do you know anything about fire extinguishers?
I have a 30X40 server room, no sprinklers, but fire proof walls and ceiling, what size and how many extinguishers should I have?
#125
#126
Hey Steve a couple abc dry chems on each end of the room should be enough as long as they are easy access ...............if you cant have easy access put one in the middle ...............sounds like your worry is a electrical fire all the fire extingushers in the room wont help that much unless you can cut the power .... quick access to the power shutoff and a small extinguisher will work useally pretty well..................if you ever do get a fire in there be very aware of the toxic smoke from electronics and plastics ...they will drop you quick!!!!!
#129
#133
Index > FIRE EXTINGUISHERS & CHEMICAL > BADGER FIRE EXTINGUISHERS > HALOTRON 1 FIRE EXTINGUISHERS
Badger's HALOTRON 1 FIRE EXTINGUISHERS are an environmentally acceptable Halon alternative portable extinguisher, and are designed to meet any special hazrad need where halon-1211 was specified and used. Halotron I is ideal for protecting office computer areas, data storage, telecommunications and high-tech clean rooms. Halotron I meets EPA approval and is the government specified clean agent alternative.
Qty Part # Description Price
24563B 2 1/2 lb Halotron 1 121.05
24567B 5 lb Halotron 1 203.33
23082B 11 lb Halotron 1 402.90
23097B 15 1/2 lb Halotron 1 579.75
I ordered 2 15lb, and 2 5lb
#134
