Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-01-2008, 08:40 AM
19expy97's Avatar
19expy97 19expy97 is offline
19expy97 is starting off with a positive reputation.
New factory tow mirrors??
Was wondering if any one on here has installed the new factory tow mirrors on their trucks? Is it plug and play?? i havent actually played with a set of these yet but is there differnt levels of power?? power fold ? power extend? Where has anyone found these?? Another site said ebay, but all i found was knock offs. A guy stopped to look at my bed liner and had them on his truck , he hates them cause he doesnt tow, and there where not power, did have time to really chat with him and didnt get his number but he said he would have traded even up for regular factory mirrors. I take it to be power they must come through as power?? i cant use any of the parts from my mirrors i have now???
  #2 (permalink)
Old 06-01-2008, 09:15 AM
Twinsdad98 Twinsdad98 is online now
Twinsdad98 is starting off with a positive reputation.
search the forum because just recently (within past month) someone actually installed them on their f150. Actually has list of parts required if your truck didnt come with power mirrors. Its possible to do, just time and money.
As to the different levels, maybe look on fords website and see the options for the new f150. I'm still not sure if there is a power fold or telescope for the ty mirrors.
__________________
2004 Black Lariat F150 Supercrew 4x4
Roush Suspension Kit, Mark LT bed rails, Truxedo Low Profile tonneau cover, Euro Tail lights, chrome handles, Edge, Volant CAI
Summer Wheels : NS Racing Black/Chrome, 20X8.5, Cooper Tires, 305/50R20s.
Project: 1950 F1
Previous:
89 Probe GT; 86 Bronco II (ex gave it away )
  #3 (permalink)
Old 06-01-2008, 09:25 AM
the_webers_inc's Avatar
the_webers_inc the_webers_inc is offline
A mostly quiet ^
the_webers_inc is starting off with a positive reputation.
I installed them on my truck. Mine are the manual telescoping, manual fold towing mirrors w/ power heated glass/turn signals/puddle lamps. Physically installing them is not a problem, but wiring can be an issue.
Installation is very easy if you have an 2007 or newer, XLT or better F-150, just plug them in and go. On my 2006, they mount fine, but you have to move a ground wire in the connector to enable the heated glass. If you have a Lariat or a truck that had heated mirrors everything will then work minus the Puddle lamps.
On trucks that did not have heated mirrors (like mine) you would have to replace your climate control unit, with a unit that had the mirror defrost button. The power distribution box behind the passengers side kick panel would have to be replaced as well. All the wiring is there, but the climate control unit and the power distribution box are incorrect.
2007 and newer F-150's seem to be pre-wired for puddle lamps. My 2006 is not.
So on my 2006 F-150 XLT, the power glass and turn signals work, but the heated glass and puddle lamps do not (yet).
Hopefully Ford Fx4 will add to what I have written so far. His truck is very similar to mine & he did all the work necessary to get everything working.
I really enjoy the mirrors. It is amazing how much more you can see with them. One note though, they do increase the overall width of your truck. This is not a problem for me as I have a 10ft door the building that I park my truck in. It does make the truck a bit too wide for some house garage doors though.
Hope that helps,
T. J.
__________________
06 F-150 XLT Scab, 6.5' Box, 5.4L, 4x4, 3.73LS - Sold
--Line-X, TruXedo Original, Nifty Catch-All Xtreme Floorliners, 2008 Telescoping Trailer Tow Mirrors
95 F150 XLT 4x4 4.9L I6 5spd - Sold
89 F150 XLT 4x4 4.9L I6 4spd - Sold
91 F150 XLT 4x4 4.9L I6 5spd - Deceased
  #4 (permalink)
Old 06-01-2008, 09:31 AM
A mostly quiet ^
Here's a link to Ford FX4's thread that details his experience installing the mirrors on his truck:
http://www.ford-trucks.com/forums/71...w-mirrors.html
__________________
  #5 (permalink)
Old 06-01-2008, 09:43 AM
Ford Fx4's Avatar
Ford Fx4 Ford Fx4 is offline
Ford Fx4 is gaining momentum as a positive member of FTE.
Hope that helps,
T. J.
T.J. I think you pretty much got everything covered, thanks for that link....I was looking for it but could not find it
Here is from my other post along with part numbers
Quote:
Originally Posted by Ford Fx4
So I finally got everything working on the towing mirrors...
So to recap everything for those of you that want to do this yourself….Truck(s) was a 2006 F-150 5.4 4x4 with standard power mirrors(no heat, signal, or puddle lamp). After looking in the doors I saw that I had the necessary wires for heat and signal already in the door.
Taking the old mirrors off and installing the towing mirrors was easy. When I got to moving the pins I had trouble with them so I bought new ones ford to put into place. The new pins already had about 3” of wire on it so I just cut the wire I need to move from the old pin and soldered it to the new wire and warped with a good quality electrical tape (not that cheap vinyl stuff) I had to move 1 pin and add 1 pin in each door…Moved one ground wire to pin #8 from pin #9 and then added the puddle lamp to pin # 11….everything else matched up…..Also for anyone wanting to add these mirrors to 06 and earlier, we use two ground pins and the new mirrors only use one so simply cut the # 2 ground off and tape it.
I also wired in the puddle lamp…..It really does a good job at lighting up the ground at night….IMO take the extra time to wire this in. You can pick up the correct wire in the drivers side skill plate….dome light wire(black/blue)….there are two of them in there so make sure you test them! I fed mime though the rubber boot on the door side then drilled a small hole along the connector taped the wire then feed in through. Again you will only have to this if you have a 06 or earlier truck…07 and up should already have this wire in the door.
I needed to switch out my heater control also with one with a button for heat activation for the mirrors….again simple to do….pull the face plate off, unscrew four screws holding the heat control to the face plate, and unclip two electrical connectors.
When I got every thing back together I went to check the heat and the light would not say on…..checked the manual and saw there needed to be a 10a fuse, a relay, and a 40a fuse installed….went to do so and the slots in the fuse box was empty!!!
So I need to order a new fuse box with heated mirrors option……Just got the fuse box in today and install was again simple… 6 connections up front to disconnect, 4 in back and 2 on the front side….also the main power cord on the back side….They give you a new power cord with the new fuse box but I just un screwed the nut holding it on and used the one I already had…..
The parts list
-7L3Z-17682-AE--------mirror Right (power, signal, heat, puddle lamp)
-7L3Z-17683-AE--------mirror Left (power, signal, heat, puddle lamp)
-6L3Z-19980-CA--------heater control
-6L3Z-14A068-DA-------fuse box w/heated mirrors
-new pins from Ford
-100ft 18gauge wire for puddle lamps (20 gauge would have been fine also as that is what the wiring diagram shows them to be)
As for the mirrors they are great the lower convex is great to look at as you have really no blind spot any more….any they look every cool too as I am about the only truck running them in the area.
Here Are a few pics
Side
retracted
Extended
Front
Here is one for comparison
I have more in my galley in you click on the link in my sig and they are under "Towing mirrors pics" & "Towing mirror install"
If you have to move the pins I have wiring diagrams of were they need to be.....let me know and I can email them to anyone that needs them.
Also you can get everything from Ed "FTE/partsguy", he is a site sponsor and will get everything you need!
-Josh
__________________
2006 F-150 4X4 Supercab XLT 145" WB 5.4 3.73LS
http://photobucket.com/06_F150
  #6 (permalink)
Old 06-01-2008, 02:22 PM
19expy97's Avatar
Hey thanks alot on the info , prices are as follow 134.75 black , 144.38 with chrome cap from tasca ford. Only problem i have is where is the unit that makes my mirrors i have now fold in??? I dont mind the manual tele. but really hate to loose the power fold. Another question my 06 King ranch has the puddle lamps now so i should be ok??? Has anyone seen these in full power on the new trucks???
  #7 (permalink)
Old 06-01-2008, 03:06 PM
slc10844 slc10844 is offline
slc10844 is starting off with a positive reputation.
I don't think power fold is an option with the tow mirrors. My 08 came with them on it and I took them off. Only had power adjust, turn signal and puddle lights. They stick out pretty far and clearence became an issue. Almost forgot, they are heated also.
__________________
08 F-150 FX4 Supercab 5.4 Auto 3.55 LS
  #8 (permalink)
Old 06-01-2008, 03:37 PM
A mostly quiet ^
Quote:
To the best of my knowledge, I don't think they are availible with power fold (yet).
Yes, if you already have Puddle Lamps, you are set.
T. J.
__________________
  #9 (permalink)
Old 06-01-2008, 07:19 PM
wreedZ71 wreedZ71 is offline
wreedZ71 is new and has a neutral reputation at this point.
Where is the cheapeast place to order these mirrors from?
__________________
2007 Ford F-150 King Ranch 4x4, 2" A/S, JL Audio TR570-CXi, Weathertechs, Passport 9500i, NFab LB 4x PIAA 520s, Mag-Hytec diff cover
2008 Lexus IS 250 RWD 6-speed auto
2007 Honda CR-V EL-X 4WD
2004 Chevy 3500 Duramax Dually 4x4
1997 Chevy 1500 Suburban 2WD
  #10 (permalink)
Old 06-01-2008, 07:53 PM
A mostly quiet ^
Quote:
Tasca Ford - Tasca Auto Group | Your Online Parts Dealer
Thats where mine & Ford FX4's came from.
T. J.
__________________
  #11 (permalink)
Old 06-01-2008, 07:59 PM
What are puddle lamps? I have a 07 King Ranch with power folding, heater, and power moving mirrors. Will this be a plug and play swap for my truck or is something else required? How would I make the mirrors move in a out?
__________________
  #12 (permalink)
Old 06-01-2008, 08:08 PM
A mostly quiet ^
They are small lights on the bottom of the mirrors that illuminate when you unlock the vehicle or open the door. I guess they are supposed to light up the ground below the doors just enough at night for a person to see puddles that my be potentially there. The parent's Five Hundred has them, the lights look cool when you unlock the car walking up to it, but they really don't do anything.
They will work with your truck out of the box. You will lose you power fold ability though. These mirrors are manual folding, manual telescoping - AFAIK. All of your other current power options will work fine.
T. J.
__________________
  #13 (permalink)
fireman28's Avatar
fireman28 fireman28 is offline
fireman28 is starting off with a positive reputation.
It is a direct swap for the 07/08 models. If you have power/heated mirrors now the puddle lamps will work. If you have and 04/06 you will have to move a couple of ground pins as stated above. I put mine on about a month ago and love them. Coming from a superduty the normal F150 mirrors just didn't do it. The new ones do stick out abit more but you will get used to them.
They are manual fold and tele to answer the question above.
__________________
'07 F-150 SuperCrew Lariat 4x4 Dark Stone
-07 ExpeditionEL Limited Dark Shadow Grey - Traded
-07 F350 KR Dually FX4 Diesel CC True Blue -Traded
  #14 (permalink)
Old 06-01-2008, 08:38 PM
What are the correct part numbers for the black mirrors? I dont want chrome or any other color.
Also how easy is it to remove the old mirrors?
__________________
  #15 (permalink)
Old 06-01-2008, 08:45 PM
A mostly quiet ^
Here you go...
Not bad. The hardest part is removing the door panels, and that is relatively straight forward.
http://www.stylinconcepts.com/images...ns/2120SCH.pdf
I used this guide from a 3rd party mirror vendor. It gives the steps for removing your old mirrors.
T. J.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
