06-01-2008, 12:27 AM
How do I fill my tranny?!
I have a 95 E150 cargo van with the "big" V8 and auto tranny. A few blocks from my house, I notticed globs of black smoke coming from me! I stopped and saw oil pouring from out of the bottom of the van. I determined the fluid to be ATF (of some type) and in all I estimate that maybe 2-3 quarts have leaked out on the ground and God knows how much before I stopped - the smoke was from it hitting the exhaust pipe. It was coming out pretty fast...
I babyed it home and by the time I got there the leak stopped (likely ran out of fluid). Now the problem is that I cannot figure out where the leak was at. When looking under it, it seemded to be coming from the bell housing area. I looked at the cooler lines (at least what I think are cooler lines - 2 hoses about 1/4 OD leading to the radiator) - they look OK, but everything under there is a dirty oily mess...
I would like to top off the tranny, let it run and see if I can find the leak while its happening, but alas I cannot figure out where the hell the fill hole on it is! There is no dipstick, no drain plug and no fill plug that I can find!! How can that be?!
Also, any ideas on what could have broken are welcome (although that is secondary to figuring out how to add ATF to it...)
