Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-31-2008, 07:53 PM
dalelisa is starting off with a positive reputation.
86 f 150 4X4 Front End shaking
have 86 f150 4X4 front end shaking really hard. New ball joints new tie rod end, line up. Sometimes every time its driven , sometimes once every 3 or 4 weeks. any help appericated
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-31-2008, 10:01 PM
Franklin2's Avatar
Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.
Take it back to the alignment shop and complain about it.
__________________
Dave F
1989 F250 XLT Diesel
  #3 (permalink)
Old 05-31-2008, 10:57 PM
86bigred's Avatar
86bigred is starting off with a positive reputation.
could be your tires.one of mine was doing this. good tire and some belts broke.i checked everything,the tire looked great.took it to get ballanced and the tire was fubared.just something to cross off your list for posibilities
  #4 (permalink)
Old 06-01-2008, 07:58 AM
going back to alignment shop this week. called them yesterday since its been alomost a month since they changed tie rod end and aligned it they said we probably run over a curb or something like that even though we only put about 30 miles on it since alignment. Will have them check front tires though didnt think about that. thanks for your help very appericated any more ideas would be appericated
  #5 (permalink)
Old 06-01-2008, 09:09 AM
Franklin2's Avatar
I am glad they are working with you, they should. Front ends are more complicated than people realize, and it's hard sometimes to figure problems out. If they get it back and think it's the tires, they will probably rotate and or balance them. A good alignment shop will usually guarentee the vehicle drives correctly when they are done, not just put it on the machine and turn a few adjustments and give it back to you. Sounds like they already checked it over once, since they replaced a tie rod. Hopefully they will find the problem.
__________________
Dave F
  #6 (permalink)
Old 06-01-2008, 09:18 AM
this is a fairly new new shop in town. but i have nothing but good things about this shop, and there prices are every cometive with other shops in town. so we thought we would give them a try. so far we are pleased with service, but truck still isnt right. also when a problem isnt contious its harder to find. so we are giving them the benifit of the doubt.
  #7 (permalink)
Old 06-01-2008, 09:24 AM
Franklin2's Avatar
It's been my experience with a wild shake, that something is still loose. I had a truck that did this sometimes when you hit a bump. Turned out it was the shock mount/bushing was loose on one side, letting the wheel go crazy when it bounced over a bump.
Something to look for on these trucks are frame cracks around the steering box area, and broken steering box mount bolts.
__________________
Dave F
  #8 (permalink)
Old 06-01-2008, 09:35 AM
thanks for the tips will check these areas out also
  #9 (permalink)
Old 06-08-2008, 11:07 AM
update
got truck back from shop friday all they did was rotate tires & check the front end over again. the said nothing wrong with front end but they thought that pinion bearing was bad.
Dad myself and a buddy just completely rebuild rear end everything new execpt the axle shafts, all new bearings new ring and pinion new seals new u joints about a month ago. but they say pinion bearing still bad. but i dont see how that will make the front end shake as bad as it does.
  #10 (permalink)
Old 06-08-2008, 05:41 PM
uncle.stosh's Avatar
uncle.stosh is gaining momentum as a positive member of FTE.
Your pinion bearing has nothing to do with your front end shaking. Especially because it is NOT even turning without the transfer case being put into 4WD and your hubs unlocked.
I would take it to another shop that knows what they are doing.....
__________________
Quote:
Originally Posted by tommythomasson View Post
Priming with a drill - what kind of drill did you use? I'm not sure my DeWalt would turn the engine over...
  #11 (permalink)
Old 06-09-2008, 12:44 AM
awrivers63 is starting off with a positive reputation.
I have a 86 Ford F-150 4x4, I have been having this shaking problem as well. I replaced my brake master cylinder today, It stopped the shaking, Apparantly the master cylinder was notreleasing the brakes completely.wayne
  #12 (permalink)
Old 06-10-2008, 05:38 PM
Well Guys thanks for all your help it is greatly appericated as always. given some ideas i nvere even thought of checking. Last night i found the problem. as Franlkin2 suggested the frame is cracked just behind the gearbox. Alignment shop said they never heard of it before, I'll not be using that shop again. I'll go back to my regular alignment shop. Anyway now i have to figure out the best way to fix it now. And thanks again for everyones help.
  #13 (permalink)
Old 06-10-2008, 05:48 PM
ri_truck_guy's Avatar
ri_truck_guy is starting off with a positive reputation.
Just out of curiosity, are you getting any kind of popping or other noises as you turn the wheel?
__________________
Bill
86 F150 4x4 5.0
05 Cadillac CTS-V
05 Mercury Mountaineer AWD
05 Harley Davidson Softail Deluxe 95ci
"Everyone has issues. It's just some people's issues are so much more interesting...."
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
