Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-31-2008, 08:29 PM
kgross is starting off with a positive reputation.
Ignition problem?
I think I have an ignition problem, but I am not sure. I have an 83 with the 300 6 in it. Was running well. My kids left the keys on until the battery went dead. Now the pickup is missing really bad and has no power. It will not idle, will not rev up very far. To me it acts like an ignition problem. I thought it was a bad coil, so I had the coil tested and according to autozone it is fine, had ignition module tested also. Cap and rotor look good. I'm not sure what else could be bad. Could a coil be bad and still test out OK?
I have thought it could be the distrubutor but I have never seen a hall effect setup that only partily worked.
Thanks in advance for any assistance.
Kim
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-31-2008, 10:47 PM
Ranger GT2's Avatar
Ranger GT2 is starting off with a positive reputation.
Have you checked to see if the coil could be going bad?
__________________
1977 Ford F100 300 six 4 speed 2wd
1982 F100 300 six 4 speed O/D 2wd
  #3 (permalink)
Old 05-31-2008, 10:52 PM
Franklin2's Avatar
Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.
I would check the voltage of the battery with the truck running. You should have something close to 14v. If it's low, then that could cause your problems.
I am thinking when you jumped it, or whatever you did to get it going, something bad may have happened to the charging system.
__________________
Dave F
1989 F250 XLT Diesel
  #4 (permalink)
Old 05-31-2008, 11:32 PM
Quote:
I had the coil tested, and they said it tested OK, It does act like a bad coil to me.
Kim
  #5 (permalink)
Old 05-31-2008, 11:33 PM
I put my charger on it. Charging system seems to be working fine. Voltage runs about 14.2 when it is running.
Kim
  #6 (permalink)
Old 06-01-2008, 06:46 AM
ArdWrknTrk's Avatar
<--Dog is my Co-pilot
ArdWrknTrk has a great reputation on FTE.ArdWrknTrk has a great reputation on FTE.ArdWrknTrk has a great reputation on FTE.ArdWrknTrk has a great reputation on FTE.ArdWrknTrk has a great reputation on FTE.
Leaving the key on can overheat the coil and break down the windings insulation internally.
This might only be apparent when the coil is hot, or under load.
__________________
"Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it." - Mark Twain
Jim
'87 F-250 4V 460, T19, 4x4, 4.10 sterling 10.25" - Lil' Red
FTE Fraternity of Blue Max
  #7 (permalink)
Old 06-01-2008, 01:20 PM
Jim,
That is what I thought but the when I took the coil in to be tested it tested out ok. I think I will borrow the coil off of my Cougar and see if that makes it run better.
Kim
  #8 (permalink)
Old 06-01-2008, 03:05 PM
81-F-150-Explorer is gaining momentum as a positive member of FTE.81-F-150-Explorer is gaining momentum as a positive member of FTE.
If the coil is over seven years old, replace it anyway.
For one, it won't hurt it.
And for two, the oil inside of an older coil can turn black, and not cool the coil as effectively as a new one. And the spark is "fresher" with a newer coil, than an older one.
And three, the test autozone does to the coil, doesn't check for heat related problems very well. It just tests to see if the coil fires.
hope this helps.
  #9 (permalink)
Old 06-01-2008, 05:15 PM
I replaced the coil and no difference.
So now I am thinking something to do with the carb.
I had somebody say it could be the EGR valve sticking open, how would I test for that?
I think I will take the carb off again and try and clean it up. A few months before this last trip I did rebuild the carb.
Kim
  #10 (permalink)
Old 06-01-2008, 08:55 PM
Franklin2's Avatar
Make a solid gasket to put underneath the EGR to temporarily block it off.
__________________
Dave F
  #11 (permalink)
Old 06-11-2008, 03:04 PM
topgo is starting off with a positive reputation.
Run a jumper wire from the battery to coil + side bypass the ballast! If your engine runs good replace the ballast wire!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
