Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-31-2008, 11:15 AM
1980F15049 is starting off with a positive reputation.
Exclamation I know.. 300 to 302 Swap Questions
Hey there, I know the story everyone says stay with the 300 i6 but mine has fried piston rings, valves, and headgasket. Smokes like a stackhouse, and burns more oil that I can keep up with so heres my questions. I have option to 351c or 302. No worries everyone my 300 will live another day just not today. I was wondering I read about perches and motor mounts, correct me if Im wrong but the motor mounts go between the engine and perch right? So that makes the perch the metal guy holding my motor mount? (dont know if I understand that right) In that case,
- I can bolt a 302 or 351 to my old "perches" w/ the use of new motor mounts correct?
- I have a Np435 Tranny that will to bolt to either the 351 or 302?
- Radiator, can I use my i6 or MUST have a V8 radiator?
- Ignition can I use the i6 ignition box?
- What else would I need to do this swap thats not mentioned above?
I appreciate all your help to give this ol' girl a new life on the road!
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-31-2008, 11:53 AM
boggerted is starting off with a positive reputation.
The 351c im pretty sure has different mounts and perches than the 300 or 302/351w engines. It also has a big block bell housing afaik.
__________________
2000 Ford Excursion-6.8L V10 gas guzzler
1984 Ford F250- my project- 351w with t18 4 speed w/ granny, gauge set
  #3 (permalink)
Old 05-31-2008, 03:15 PM
81-F-150-Explorer is gaining momentum as a positive member of FTE.81-F-150-Explorer is gaining momentum as a positive member of FTE.
It will be cheaper in the long run, just to put another 300 in it.
Not sure of the perches, but you will have to replace the radiator with a V8 one.
If it's a duraspark II ignition, with a BLUE grommet you can reuse it with a V8, using a BLUE gromet DSII.
You will need all the components for the 302 engine, air cleaner, power steering pump brackets, hoses, altenator brackets, air conditioner brackets etc...
  #4 (permalink)
Old 05-31-2008, 03:44 PM
woodbutcher05 is starting off with a positive reputation.
351C has SMALL block pattern on the bellhousing.
Leo
  #5 (permalink)
Old 05-31-2008, 03:54 PM
Well looking around on craigslist found a 351w complete from carb to pan how bout that with my bellhousing? The reason I'm not looking for a 300 again is because I plan on rebuilding this one a putting it back in down the road, and using the 351 for a later project.
  #6 (permalink)
Old 05-31-2008, 07:03 PM
Franklin2's Avatar
Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.
The perches are the brackets mounted on the frame. Your 300 perches will not fit, so you will have to go to the junkyard and grind the perches off a v8 truck, and install them on your frame. Then you can buy the rubber mounts to fit between the perches and the engine.
The 351w will fit the bellhousing. Make sure you get a flywheel or flexplate for the 351w, the 300 plate will not fit.
Make sure you get a rear sump oil pan on the 351w. If you get a 351w from a car, then it will have a front sump or a double sump, which will not work, and you will need to go to the junkyard and get a rear sump pan, dipstick, oil pickup tube, and main bearing stud to hold the pickup tube.
Then you will need;
exhaust
throttle cable
possibly a radiator
new radiator hoses
may need to extend some of the wiring
__________________
Dave F
1989 F250 XLT Diesel
  #7 (permalink)
Old 06-01-2008, 08:27 PM
86step is starting off with a positive reputation.
if the 351w is from an automatic, doesn't it need a flywheel to work with the manual?
  #8 (permalink)
Old 06-01-2008, 08:47 PM
Franklin2's Avatar
Quote:
A flywheel for a manual tranny. A flexplate for a automatic.
__________________
Dave F
  #9 (permalink)
Old 06-02-2008, 03:37 PM
That guys that helps alot, the 351w I found is an older motor with a points system, and missing a carb but rebuild 5000 miles ago. Will I need the new distributor to work with my current ignition?
  #10 (permalink)
Old 06-02-2008, 07:44 PM
You will need a duraspark II Distributor to work with a Duraspark II ignition module.
  #11 (permalink)
Old 06-05-2008, 03:11 AM
Stevan is starting off with a positive reputation.
Interesting, I did the swap 10 yrs ago I6 to 302. I can barely remember it. Do the V8 mounts go over the I6 ones? I remember chisiling some rivets off (I think off the V8 donor truck) to get the mounts off, and then bolting them on mine.
Now I want to go back to the 6.
Before this truck I had an F-100 w/I6 and manual 3spd w/OD. always new I should have never got rid of it.
  #12 (permalink)
Old 06-06-2008, 04:35 PM
FTE Sponsor
PerfDistIgnition is starting off with a positive reputation.
Quote:
If you decide to get a new distributor, consider our custom curved Duraspark Distributor built with our new Full Length Oil Impregnated Bronze Bushing. The full length bushing improves timing stability and spark scatter. If stock appearance is not an issue, take a look at our one piece D.U.I. Distributor. Whether you choose the Duraspark or the D.U.I., we curve each on a distributor machine based on your engine combination. Please see them at:
http://www.performancedistributors.com/forddistributors.htm
Also, there is now an excellent installation article on the D.U.I. Distributor on the Ford-Trucks.com site at:
http://www.ford-trucks.com/article/idx/0/358/article/DUI_Ignition_Installation_In_A_Ford_351W_V8.html
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
