Steering column rebuild
#31
Am replacing steering column in 1970 F100 truck. The replacement column apparently is not the same as the original, but I can make it work. Problem is that the replacement shaft requires a replacement steering wheel. I cannot identify the year/model that corresponds to this shaft. See photo. The top shaft is the original. Notice the threads for the steering wheel. The bottom picture is the replacement. I need a steering wheel that will fit this arrangement of threads and clearance. Can someone identify the year/model of this replacement shaft? Thanks.
#32
The bottom picture with exposed 4 way flasher **** is the replacement.
Same two spoke steering wheel (repro'd by Carpenter) using a horn pad: 1971/77 F100/350; 1974/77 Bronco; 1975/77 Econoline except 1975/77 F100/350 & Econoline with Speed Control.
3 speed manual shift collar same: 1961/77 F100/250.
1978/79 F100/350, Bronco & Econoline use different steering wheels, T/S switches and horn pads than 1973/77's.
lauxg
01-09-2020 07:51 AM
chillman88
19
01-21-2017 09:58 AM
idealtrucks
11-07-2016 03:04 PM
GreaseMnky85
19
03-23-2016 01:45 PM
