Go Back   Ford Truck Enthusiasts Forums > Misc. > Appearance & Dress-Up
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Appearance & Dress-Up SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 05-31-2008, 04:54 AM
capnmorgking capnmorgking is offline
capnmorgking is starting off with a positive reputation.
Question polycarbonate windows
has anybody ever used these on a ranger? if you had to form them what are some tips?
  #2 (permalink)
Old 05-31-2008, 04:31 PM
triton_2002's Avatar
triton_2002 triton_2002 is offline
triton_2002 is starting off with a positive reputation.
they scratch really easy, is that an issue?
__________________
2002 F-150 Supercab 5.4 Triton V8
Arizona Biege
  #3 (permalink)
Old 05-31-2008, 06:41 PM
no scratching isnt an issue.
  #4 (permalink)
Old 06-03-2008, 03:04 AM
ReAX's Avatar
ReAX ReAX is offline
2002 Ford F-250
ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE.
I don't know how it applies, but lexan is really pliable under heat. Not to mention, I think most of the professional poly-glass is half as thick as automotive safety glass, so you window seals will not be very tight.
Is there a particular reason you want to use it?
__________________
Too many mods to list, so click here.
Here are my tech write ups
Look, see these two tow hooks? They look like tusks. And what kind of animal has tusks?
  #5 (permalink)
Old 06-03-2008, 07:16 PM
the glass is plyable at way higher heats than it will ever see on the road.and it comes upto a 1/4 in thick with 4 other thicknesses so that isnt a problem with seals. want to use it to lighten up my truck.just bought a 99 ford ranger 2.5 standered cab and short bed with a stick so i drive that more since it gets roughly 28mpg,my other one is quickly becoming a offroad/play truck.
  #6 (permalink)
Old 06-03-2008, 11:49 PM
ReAX's Avatar
2002 Ford F-250
I was warping lexan with a hair dryer, at least in florida, the cab can get extremely warm in the sun. I'd still be somewhat concerned.
Is there going to be that much difference in weight? I'd think only 50-100 lbs difference, nearly the same as dumping the a/c and emissions controls.
__________________
  #7 (permalink)
Old 06-07-2008, 12:51 AM
dump the a/c and u get to hot in the desert,engine wont run without most of the emission junk.
  #8 (permalink)
Old 06-18-2008, 11:09 PM
Chauncey's Avatar
Chauncey Chauncey is offline
Chauncey is gaining momentum as a positive member of FTE.
I think most polys will yellow over time in direct sunlight. Look @ all the headlamp assemblies driving around were you can't even see the bulb inside because of the hazing. And those are automotive grade with a protective surface finish. I doubt you can buy sheet poly @ the home improvment store that can measure up to that standard. As far as professional grades, I'm sure you're talking major money here. Sometimes, great ideas are only great ideas and not practical. Of course, this is just my opinion and I may be way off base.
__________________
"GREENIES" BEWARE-My goal is to use my full share of the available fossil fuels plus any shares left unclaimed!
06 F-150 Lariat SCREW
08 6.4 SD 250 King Ranch crew 4X4
08 Solstice GXP (we be going racing now!)
  #9 (permalink)
Old 07-20-2008, 01:28 PM
magusjinx magusjinx is offline
magusjinx is starting off with a positive reputation.
If you insist on a poly window I would chat up someone in the armored vehicle venue ... They have the best ...
__________________
Current:
1986 Ford F250 XL Exploder--4x4, 6.9 NA IDI, C6
.. body by Rusty Crunchy
1986 Jeep Cherokee Pioneer Limited P.O.S.--2.8L V6, Automatic ...
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
