Venting R134 into the atmosphere & recharging are one thing. How do you evacuate the system after reassembling it to prepare it to be recharged?
Quote:
Originally Posted by Eatonpcat
Just call me Mr. Shadetree.... I believe doing it myself cost around $300.00 (including new belt & recharging system), I can't imagine what a shop would charge. Sometimes the enviroment has to take a hit.
Leaving air & moisture inside the system may well lead your repair "to take a hit" prematurely. I've got a vacuum pump, an AC gauge manifold & an old friend w/refrigerant recycler.
Perhaps I did not make it clear that many a "DIYer" can R&R the compressor, leaving just the recharge to a pro, for someone w/o any AC tools.
Its also unclear if your "Mr. Shadetree" referred to replacing the compressor's bearing, which can require "special tools" or just swapping out the compressor.
