List of mileage boosters - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 05-30-2008, 12:45 AM
AltaEx AltaEx is offline
AltaEx is starting off with a positive reputation.
This has been discussed over and over but I haven't seen a comprehensive list developed. Can we TRY that here - each poster simply copy the latest poster's list and add their own points. (Leave discussions to other threads and just stick to point form itemization. Embellish or create improved comments rather than trash a prior person's item - whether it's rightly or wrongly in the list at all.)
Maybe don't worry about order - it's highly debatable as are my categories
Generally Easy and Cheap
- improve driving style
- remove roof rack crossmembers
- higher tire pressures
- use a winter front in the winter (air dam effect and impoved engine temp.)
- carry less weight
Less than roughly $500
- engine tune up
- after market air filter
- after market exhaust
- diesel chip
Over $500
- change to highway vs offroad tires (reduced rolling resistance)
- remove push bars, etc.
Involves work, testing and uncertain costs and results
- improved aerodynamics
- - air dam
- - underbelly smoothing
- - rear deflectors
- hydrogen generators :-) (just kidding)
Old 05-30-2008, 04:39 AM
Monsta's Avatar
Monsta Monsta is offline
Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.
- Scan Gauge II (or similar) to monitor Load, Throttle Position, manifold pressure etc. to help improve MPG driving style.
- carry less weight
- keep your engine clean
- proper weight oil
- verify proper tire alignment
- engine tune up
- diesel chip
Over $500
- - air dam
- - rear deflectors
- Flux capacitor serious...
Old 05-30-2008, 08:09 AM
katiesdad7 katiesdad7 is offline
katiesdad7 is gaining momentum as a positive member of FTE.
I found an easier way to save fuel. Get someone else to drive you. :-)
Old 05-30-2008, 11:49 AM
aklim's Avatar
aklim aklim is offline
aklim has a very good reputation on FTE.aklim has a very good reputation on FTE.aklim has a very good reputation on FTE.
Quote:
That doesn't work as well as the Bussard Collectors.
A highly fictionalized variation of this concept, called the Bussard Hydrogen Collector or Bussard Ramscoop appears in the Star Trek saga as part of the matter/antimatter propulsion system that allows Starfleet ships to travel faster than the speed of light. In the saga, the ramscoops attach to the front of the warp nacelles, where (when the ship's internal supply of deuterium runs critically low) they collect interstellar hydrogen and convert it to deuterium and anti-deuterium for use as the primary fuel in a starship's warp drive.
Old 05-30-2008, 01:24 PM
MarkMoore's Avatar
MarkMoore MarkMoore is offline
MarkMoore has a great reputation on FTE.MarkMoore has a great reputation on FTE.MarkMoore has a great reputation on FTE.MarkMoore has a great reputation on FTE.
Dude - I'm a Star Terk fan but....
Old 05-30-2008, 02:51 PM
ukmat71's Avatar
ukmat71 ukmat71 is offline
ukmat71 is gaining momentum as a positive member of FTE.
did someone mention flux capacitor ?
click here
Old 05-30-2008, 02:54 PM
aklim's Avatar
Quote:
click here
Holy Crap. It is 15% off. I'm getting mine NOW.
Old 05-30-2008, 07:07 PM
Monsta's Avatar
Don't buy from them. I bought the engine oil bypass kit to help reduce pumping losses and found that my mileage went UP. I'd like to get the dual o-pipe but won't buy from them. I'll wait until somebody else carries one.
Oh boy...
Old 05-31-2008, 12:57 PM
- Vacuum gauge (cheaper?)
- carry less weight
- proper weight oil
- engine tune up
- diesel chip
Over $500
- - air dam
- - rear deflectors
- - trim windshield w/electrical tape smooths airflow, cuts noise and fixes leakes too :-)
- - Vortex Generators (air tabs)
Note: sounds like Vortex Generators beat Hydrogen Generators.
http://www.mitsubishi-motors.com/cor...004/16E_03.pdf
url=http://www.autospeed.com/cms/A_3061/article.html
Old 06-01-2008, 10:40 AM
FordCrusherGT's Avatar
FordCrusherGT FordCrusherGT is offline
FordCrusherGT is starting off with a positive reputation.
Best way to get better mileage:
Stop driving the Excursion, drive something that gets better mileage instead.
Old 06-01-2008, 12:45 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32 weekendwarriorfsw32 is offline
Master of Strokes
weekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud of
If you have the 7.3 you can also try this Clean you out your EBP
Welcome to guzzle's Exhaust Backpressure Sensor Cleaning Maintenance Web Page
Old 06-01-2008, 12:49 PM
scottman70's Avatar
scottman70 scottman70 is offline
scottman70 is gaining momentum as a positive member of FTE.scottman70 is gaining momentum as a positive member of FTE.
Exactly! That's what I did 2 weeks ago! Drving a 25mpg vehicle now and it's nice saving $$$$ I will only drive the Ex for towing, the rest of the time it's parked in the garage!
Old 06-01-2008, 09:17 PM
Yes - I guess walking works too. I've added it below..
- walk or take a bus or borrow someone else's car, take a balloon (or whatever involves just not driving the EX which has the benefit of reducing its depreciation)...
- carry less weight
- drive something else (if you have it)
- engine tune up
- diesel chip
Over $500
- Buy something else (if you have to)
- - air dam
- - rear deflectors
Snow + Air Dam? Robbgt 2009 - 2014 F150 10 11-14-2013 07:45 AM
Article on additives, interesting read Gettysburg150 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 04-12-2013 02:39 PM
Air Dam on a '12 johnday 2009 - 2014 F150 40 03-29-2013 07:12 PM
2002 F150 Supercrew 4x4 front lift Ohio_Muddy_Truck 1997 - 2003 F150 2 09-07-2002 12:00 AM
Blocker beam removal ceferino Excursion - King of SUVs 1 03-23-2001 12:25 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
