dump pump question...
Old 05-29-2008, 10:44 PM
Miller's Avatar
Miller
Miller is offline
do you guys use electric water pumps to recover WVO or do i need an oil pump?
Old 05-30-2008, 09:04 AM
willbd's Avatar
willbd
willbd is offline
Fill-Rite 7 GPM/10.5 GPM, 12/24 Dual Volt DC Pump works good.
I am now using a Diaphragm pump that will pump up to 3/8th inch solids. You will need a pump that is self priming.
Old 05-30-2008, 04:18 PM
Tom D's Avatar
Tom D
Tom D is offline
Where is the best place to get an inexpensive diaphram pump? The ones I saw were pretty pricey. Thanks Tom
Old 05-30-2008, 04:41 PM
willbd's Avatar
willbd
willbd is offline
I don’t know where you can get one cheap. I am using a 1 inch double pneumatic pump that’s $1200 new. It will flow about 45 GPM is you have enough air. The list price in Grainger is between $250 and $3400. The low end is ¼ inch inlet and the high end is 2 to 3 inch inlets.
The beauty of the diaphragm pump is they will pump anything.
Old 06-01-2008, 06:44 AM
Gun-Driver's Avatar
Gun-Driver
Gun-Driver is offline
I use a gas powered 2" trash pump bushed down fto 1" hose for easier handling. Works great even in the winter when the oil is really thick.
