Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-29-2008, 11:29 PM
George D.'s Avatar
George D. is starting off with a positive reputation.
Head gasket in a can?
Since my thread about my engine isn't getting much attention I figured I would start a new one to ask. Is that stuff you pour in the cooling system run the engine up to temp then flush the cooling system and is suposed to fix cracked blocks head gaskets and cavitation any good? Does it work?
I was wondering since i have virtualy no extra money to buy parts for my truck and no other form of transportation. After i pay rent I will have ten bucks till pay day.
__________________
94 F350 Crew Cab Long bed 4X4 7.3L IDI Factory Turbo, AKA The Land Yacht. E4OD, 4.10 posi. Getting further from stock with 35 inch BFG alterains on 16 inch micky's, straight pipe, Triple A-piller pod with pyro, boost, modifyed stock oil presure gauge, tc lock light&switch
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-29-2008, 11:55 PM
catfish101's Avatar
catfish101 is starting off with a positive reputation.
George, those things are a waist in my opinion. Yeh, there are "stopleaks" that will stop some leaks but they make a mess out of motors, power steering pumps, AC compressors ect.
As far as which ones may be better, I don't know. I haven't ever messed with any of those things.
__________________
79/83/86/95 F-??? 6.9 4speed
94 350 4x4 SRW 7.3 factory turbo
1930 Model A Original
My wife has three of her own.
  #3 (permalink)
Old 05-30-2008, 12:21 AM
S.P. is starting off with a positive reputation.
stop leak
I've used the copper/aluminium powder to stop rad. leaks....and some kind of block sealer, I've found that some work some times /sometimes for quite sometime...All I can say is you have to read all the instuctions and follow them to a tee-------(te--tea--somthin like that)LOL...good luck I hope it works out for you...S.P.
__________________
"YOU'RE JUST JEALOUS THAT THE VOICES TALK TO ME"
1991 F250 X/cab, 4X4, 7.3l, w/ATS Turbo, Lariat, egt & psi gauges, 33" tires, and now with a 5th wheel hitch..
  #4 (permalink)
Old 05-30-2008, 01:59 AM
troutski is starting off with a positive reputation.
Blue Devil?
The local diesel guy recommended "Blue Devil" as he said a truck like mine ('86 2wd) wasn't worth fixing the HG leak. Said it works sometimes, and is worth giving it a shot...
The issue seems to be getting the thermostat out. It looks like you have to take most of the left side of the motor apart. (alt, etc) just to get at the bottom bolt on the TStat housing....
Just how much stuff does one have to remove to get the d*&m thing out?
Mark
'86 2wd with a leaky HG....
  #5 (permalink)
Old 05-30-2008, 06:40 AM
FORD MEGA CAB!!! is starting off with a positive reputation.
I used some In a 4 cylinder mazda pickup. It was dumping coolant and had a constant flow of white smoke out the tail pipe. Well, I bought some of that block seeler at autozone but i don't know what brand it was. It was mostly clear with gold in the bottom of the bottle. When you shake the bottle, it turns all gold. Anyway, I followed the instructions to a T and worked great. I drove it for 2 weeks and then sold it. Bottom line is, If you need a quick fix now, then It probably wouldn't be a bad Idea to use/try it. I don't think The stuff will hurt anything. My only concern was clogging the heater core. Im also not sure how well It will work with these higher compression engines either. Well good luck
__________________
LOADED LIKE A FRIGHT TRAIN, FLYING LIKE A JET PLANE.
1993 Ford Mega cab long bed dually diesel 7.3 IDI w/Banks sidewinder Kit, e40d w/4:10s
1995 chevy K1500 4x4 350 4l60e
1990 suzuki sidekick 4x4
  #6 (permalink)
Old 05-30-2008, 11:13 AM
thosfsull is starting off with a positive reputation.
Blue Devil is some nice stuff, though it is like $60 a bottle. It works very well, however, it is best used as a temp patch when in a pinch that can buy you some time.
My buddy used at his body shop for the poor customers who couldn't afford a head gasket to make it through till they could afford one. Funny thing they have all lasted at least a year plus. Some three years, but you have to follow the directions to the LETTER on the instructions, otherwise it won't work.
Blue Devil Engine and Cooling Sealant (32 oz.)
The Automotive Blog » Blog Archive » Blue Devil Engine and Cooling Sealant (32 oz.)
Universal Products, Inc.: Blue Devil Product Overview
Universal Products, Inc.: Blue Devil Directions for Use
  #7 (permalink)
Old 05-30-2008, 10:15 PM
Dave Sponaugle's Avatar
Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.
An 86 6.9 is one of the best IDI motors they made.
I would fix the head gasket in a heartbeat.
Your mechanic would probably tell you I was nuts, I dumped about 4000 dollars in my rebuild, and that was just parts and machine work.
I did all the labor myself.
I was smiling big time today, just had to blow some black smoke on a Dodge dude that thought he had a bad truck.
Turned out it was bad, but the kind of bad he had was not the kind he thought he had.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #8 (permalink)
Old 05-31-2008, 07:48 AM
Eric C.'s Avatar
Eric C. is starting off with a positive reputation.
If you're getting rid of the truck anyway use it and dump the truck. If you're going to keep it, find a new mechanic and get the head done. Don't run it to long with a leak or it'll cost you a lot more and the more you run it the worse it gets. All the heavy duty engines I've worked on over the years this stuff never last, but this is my opion and $0.02.
__________________
87 F-250 4X4 Diesel
88 F-150
89 F-350 Crew Cab (DECEASED, killed by a tree)
94 Aerostar
93 Tarus GL Station Wagon
I Love the smell of Diesel in the Morning, It's the smell of $$$$$$$
  #9 (permalink)
Old 05-31-2008, 12:11 PM
Smile why the HG in a can trick...
Eric,
I have no intention of getting rid of the truck. I have a rebuilt 6.9 sitting on the stand. I am looking for a pipe for the ATS set up I just got, to install it, so I'm just buying time...
I'll post separately about the exhaust piece I need for the turbo set up.
Thanks for the info, I know this is just a band aid, and sorry for the
Mark
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
