You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Well guys, here it is. Here are some pictures of our new 40 gallon auxillary Excursion Tank. There are still a few refinements and adjustoments that need to be made, but this is basically it. This is an all aluminum heated auxillary tank that is comletely independent of the OEM tank. There is a 30 gn low profile tank as well that will be 3" more shallow. We are particularly porud of our filler door solution. Sound off and let us know what you think!!
I admire the engineering work ya'll did on that truck. Though I don't foresee buying an Excursion since we have the F250...but my wife could always upgrade from the Explorer to an Excursion; I'll keep this kit in mind. Really nice looking work there guys.
__________________
FTE Arkansas chapter member
1972 Ranchero GT (351C CobraJet intake)
2001 Explorer XLT 2WD
2004 F250 6.0L 2WD CC "Pavement Princess"
2007 Monaco Starwood SL 31BHD
2012 Focus SEL (Wife's ride)
how about a strap on that new tank, or are the mounting tabs strong enough? considering weight. Looks good love the filler solution
Yep, the mounting tabs are plenty strong enough. Oil is ~7.6lbs/gn times 40 gallons equals 304lbs, divided by 4 tabs is only 75lbs per tab. Each tab has been tested to support over 250lbs without defection. So really the tank should be able to easily support 1,000 lbs. The only thing that I will likely do given how far down that tank sits is weld a double layer on the bottom.
And on the filler door, you can lock it too with the door locks so no one can steal our valuable oil...
