Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Bronco > Big Bronco (1978 - 1996)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-29-2008, 05:25 PM
mutang460 is starting off with a positive reputation.
Timing my big bronco
Hey I have a 79 with a 351 M,,, what is everyone setting there timing at, and what cylinder is the number one cylinder
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-29-2008, 05:51 PM
alxsnmr is starting off with a positive reputation.
If it is dead stock, the timing is set at 10 degrees BTDC or as indicated by the FoMoCo tag on the valve cover or somewhere in the engine compartment. This is set on a warm running engine with the vacuum advance disconnected.
Number 1 cylinder is the Front cylinder on the passenger side of the truck. Ford numbers the cylinders on the passenger side first as 1,2,3,4 then the drivers side front to back as 5,6,7,8.
__________________
Stock 1978 F250 Custom regular cab 4x4 with 351M and 4 spd.
1991 Bronco silver anniversary, 5.8L EFI, E4OD swapped for C-6, otherwise still stock.
  #3 (permalink)
Old 05-29-2008, 10:11 PM
thanks man, thought that was the order of the cylinders but just wanted to double check,, yea its basicly stock,
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
