Join Our Site - Its free, quick and easy!
Click Here to join.
05-29-2008, 10:03 AM
carb flow
Whats the cfm flow on a early 80's 351w carb?
| Sponsored Links |
To remove this ad, register today!
05-31-2008, 07:18 PM
__________________
89' F150, 302, 4x4, AOD, 131k
74' F250, 390, 2wd, C6, 51k
06-01-2008, 01:58 AM
2bbl, not much over 350 max if that
4bbl, not much over 500, if that.
Somewhere on here it's be posted, use the search feature....
06-02-2008, 11:49 PM
4bbl would be 600cfm
2bbl, we need the .1?? number stamped in the carb.
06-03-2008, 08:21 PM
Weren't the 4bbls 465 cfm?
__________________
06-03-2008, 08:30 PM
The two barrel flows 356 CFM. Same one was used on the 82 Mustang GT's.
06-03-2008, 09:57 PM
No, the 4bbls were 600cfm Holley 4180's.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
