Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Brakes, Steering, Suspension, Tires, & Wheels
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Brakes, Steering, Suspension, Tires, & Wheels Click Here
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-29-2008, 07:29 AM
michaelmoo is starting off with a positive reputation.
’72 LTD rotor/drum swap on a ‘73 F100
I have a ’73 F100 longbed and have been looking for aftermarket wheels. I also need to d a brake job (need new front rotors). This leads me to a few questions.I read that a guy here changed his front disk and rear drums to a 5 x 5” bolt pattern by using the parts off a ’72 LTD (and had the rear hub machined to the correct pattern). He claims that the bearings and seals are the same. I looked on AutoZone’s website and confirmed that the inner and outer front wheel bearings are the same part numbers. The seals had different parts numbers. Has anyone ever done this? Is it as simple as swapping the disk, drums and machining the hubs? -MikeI’d like to run Torq-Thrust Originals (TTO) on the truck (which is why I want to do the 5on5 conversion). But they have a back spacing of 3.75”. Would I need to get a 0.25” spacer to make the backspacing the correct 4”?
Sponsored Links
To remove this ad, register today!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
