purple hornies
if your neighbors are abunch of old people they are probably gona be fairly pissed. If you have headers and bolt them up to that and dont run any tubes to behind the cab there is a slight risk of carbon monoxide poisoning. If you are in alot of slow traffic, keep the windows down and keep some air moving thru the cab. If you are on the highway you should be fine. Welcome to FTE by the way, there are alot of good guys on here, you can learn alot. What truck is are you puting them on? Also you should pick up a few horses from a stock exhaust or even from having a system, there should be less back pressure on the motor. Personally I would get the 3rd one down because the outlet is bigger witch means even less back pressure.
hornies
thanks for the advice and the welcome its going on a 87 f250 with a 460 big block that im slowly building up great mudder love this truck runs like a champ and i get 15 miles to the gallon i cant believe it... are you talking straight bolt on to the headers???? i was gonna tube it down to atleast the rear wheels but if it sounds and does better that way i will
Most of the guys up here that have them use them on race cars, they just bolt them up to the headers. It will work and if you dont have acsess to a pipe bender to bolt them up to the headers. It would work for now if you make sure you get some fresh air in the cab. That is if you have headers not just the stock manifold. That is increadible that you get 15mpg on your 460, on mine I get a 8-9 highway and about 6 city. Also I take it that yours is a carb not efi?
The old headache, hearing loss & CO poisoning models.
We used to call them "Roll Control Mufflers", on the theory (developed in a state of partial intoxication) that they hung so low that if the car leaned in a corner, the muffler would touch down first, springing the car back to level.
Every loud muffler potentially produces a vote for a potential office holder who makes part of his package a law banning ANY modification to vehicles.
Every load muffler provides a reason for law enforcement to take a closer look at you and your vehicle.
If you like pissing others off, you are on the right track.
If I was your neighbor and you came in late and woke me up, you would soon find yourself in need of paint, tires, gas tank flush, many many maintenance items associated with being a nuisance.
carb
yeah i have the carb im thinking about going to EFI though any thoughts on that??? i may put a eaton blower on it too i'll have to see the price on that first just a thought got a valve cover leak noticed today actually so putting the packs on and replacing the seal on that will be my weekend choir
Jesser02EX
11-14-2013 10:24 PM
xc4jokestomper
16
05-24-2012 11:30 PM
