GVWR vs Axle wt
GVWR vs Axle wt
So, if my total wt. is 7080 lbs and my GVWR is 8800 can I only load the diff into the bed?
My axle ratings are 4600 for the front and 6XXX for the back.
I weighed in at 4030 on the front and 3XXX on the back.
Can I put in another 3,000 lbs in the back roughly to up to 6000lbs total on that axle or will I be overloading it.
Which set of numbers should I go with?
