you can buy one from shucks or napa or car quest pretty much any place that sells a car part SHOULD work... as for instalation... its simple... 3 or 4 wires depending on the model... one goes to the positive side of the coil... another goes to ground... and positive on the battery... and if you got the one with 4 wires, the 4th gose to the light switch... so that when you turn on the lights... it turns on the light in the tach... and then there is a switch on the back for 4 6 or 8...[the number of cylenders... so select 8... but be cautious... there was a guy in the 61-sixty what ever... saying that his tach was reading correctly when the switch was selected to 6... but he had a V-8] then just mount it where you want it...
if you get a new one, you will get the instructions in the box with all the mounting wires and everything
__________________
1963 ford f-100
with 292 Y block.
headers
elec. fuel pump
1997 dodge stratus
all stock
daily driver/hunting rig/never get stuck/mini-truck
"my girlfriend may hate my truck... but i still love her(the truck not the girlfriend)"
x=gas costs
y=mpgs
z=truck
r=rich
[x2](y)+z=r
Reason: wrong info
