Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > 401, 477, and 534 SD Engines
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 05-28-2008, 03:47 PM
jbh174 jbh174 is offline
jbh174 is starting off with a positive reputation.
477 or 534?
I am searching for a way to distinguish exactly what engine is in my 1969 F-100 Super Duty single axle dump truck. For the many years I have owned the truck I was under the impression it had the 534 CID engine. However, the carb has been giving me issues lately and upon researching the holly numbers (List# - 6284) it claims to be for a 477 CID engine. The carb could have been replaced at some point in the trucks history, but I would still like to confirm what engine the truck has for future parts inquires. How can I find this information?, I believe the engine to have never been out of the truck but I can't be 100% sure. Thanks in advance.
  #2 (permalink)
Old 05-29-2008, 02:00 AM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE.
Shorter stroke in 477, enough that you can probably measure using a wire or small dowel through a plug hole:
Quote from another post here:
"""You asked for it, from the Motors Truck Repair manual (C) 1979.
'66-72 477 - 4.5 x 3.75" 7.5:1 4 bbl carb HP:253@3400, TRQ:415@2300
'66-72 534 - 4.5 x 4.2" 7.5:1 4bbl HP:266@3200 TRQ:481@1700
In '73, they went down to 7.2 (477) and 7.3 (534) compression and the numbers went way down because of "net" hp/trq. In '75, there is a 475, same bore/stroke as the 477. The 475/477/534 were used up until '79, the end of my book.
Quick edit: there was a 2bbl 477, early on, in '66/'67, with HP:231@3400 and TRQ:412@1600 """
Which was from this thread:
http://www.ford-trucks.com/forums/17...ial-555-a.html
Somewhere here are all the bore/stroke specs + more for the 401/477/534.
Tags
477 , 534 , bore , cid , cu , engine , ford , hp , list6284 , manual , motor , parts , specification , specs , stroke , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
