Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Bronco > Big Bronco (1978 - 1996)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-27-2008, 09:40 PM
gov2mod is starting off with a positive reputation.
Rear window mystery, I'm baffled.
I can't get the back window on my 93 Bronco to work. I replaced the front switch, tested the back switch, and the motor runs fine in both directions when I put 12V to it. I've checked the wires for continuity all the way to the front switch. If I give it a ground wire at the rear switch on one side it will work one way. If I give it a ground on the other side it will work the other way. If I add a ground at the front switch on one side or the other it will work either way. It's getting 12v power all the way to the motor but without a secondary ground source it won't work. I've had the plugs apart behind the gas tank and at the firewall. I've not found any shorts, dirty plugs, or broken wires. I'm baffled.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-27-2008, 11:21 PM
Montana Mark's Avatar
Montana Mark is starting off with a positive reputation.
The ground circuit goes through the front switch, if the contacts in there are worn/burnt/dirty neither switch will work. Mine was doing the same thing. I rewired my back window by adding two relays. The back windows works better now than it ever did. If you want some details, let me know.
__________________
Montana Mark
1978 F150 4X4 "The Great Pumpkin"
1989 Bronco Eddie Bauer
  #3 (permalink)
Old 06-01-2008, 09:54 PM
bossind's Avatar
bossind is starting off with a positive reputation.
Might have a bad ground, the switch reverse the polarity to the motor so the window goes up and down. From the testing you did there is power, but no ground.
__________________
-Steve
96 Bronco, SAS, 4.88, 35s, Hydro Boost, 3" exhaust, 4 wheel Disc brakes, Sag PS Pump.
  #4 (permalink)
Old 06-01-2008, 10:04 PM
I'm sure that's the problem, I can't see where the ground is from on the front switch end.
  #5 (permalink)
Old 06-02-2008, 12:04 AM
80351's Avatar
MD Chapter LDR
80351 has a great reputation on FTE.80351 has a great reputation on FTE.80351 has a great reputation on FTE.80351 has a great reputation on FTE.80351 has a great reputation on FTE.
Mine did exactly the same thing,
I finally tracked it down to the connector
between the motor and door latch.
Itook out that connector and installed a
new one and it works fine.
__________________
Dave MD Chapter Leader
Mid Atlantic
89 Bronco 90 BII
03 Liberty
Join the Maryland Chapter click HERE
Jeepers Cheat, Ford people are true Blue
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
