Monster TRUCK! - Page 4 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Monster TRUCK!
  #46
Old 05-29-2008, 03:00 PM
aander88's Avatar
aander88 aander88 is offline
aander88 is starting off with a positive reputation.
all ive got for you is....jealous!
  #47
Old 05-29-2008, 03:55 PM
Imondi's Avatar
Imondi Imondi is offline
Imondi is starting off with a positive reputation.
I had three fill-ups between Phoenix and Denver, all of which were between 13 and 15 mpg. That's highway though, city mileage isn't pretty i will tell you that!
And I did not come here looking for criticism, I had a question on whether anyone had any experience with a wheel and tire combo that I am interested in. You can say whatever you want about it...I will build it the way I want it and if you want one different, then get off your ***, get a job, and build one for yourself!
  #48
Old 05-29-2008, 04:01 PM
captain p4's Avatar
captain p4 captain p4 is offline
captain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud of
Quote:
anyway...
did you recal the speedo for the huge tires? I'm willing to bet thats why you think you're getting such good mileage.
  #49
Old 05-29-2008, 04:12 PM
Imondi's Avatar
No, i havent't recalibrated the speedo yet, but that would have the opposite effect. It would show that you went less miles than you actually did. I had a buddy follow me in a small car and used his odometer when filling up. Then, when I got home, I mapquested the distance from my house to the gas station I filled up at before I left phoenix. I used that distance and the total amount of fuel I used on the entire drive to calculate the mpg...if there is a more accurate way of doing it, please let me know!
  #50
Old 05-29-2008, 04:14 PM
SUPERDUTY_untouchabl's Avatar
SUPERDUTY_untouchabl SUPERDUTY_untouchabl is offline
SUPERDUTY_untouchabl is gaining momentum as a positive member of FTE.
Did the stock trany give out or did you just have it rebuilt? Great looking truck btw.
  #51
Old 05-29-2008, 04:18 PM
78bigbronco's Avatar
78bigbronco 78bigbronco is offline
78bigbronco is gaining momentum as a positive member of FTE.
Actually that would be the opposite, bigger tires with same cal would mean for every tank of gas the odo would show a lot less miles. Now with whatever calibration has been done I wonder if its accurate, not that a doubt the mpg too much, the 7.3 often got pretty good milleage. But I worry about the axles a little.
Edit: you ninja'd me. As far as a more accurate way I'd say find a friend with a gps and borrow it, or spend $100 on a programmable spedo.
  #52
Old 05-29-2008, 04:40 PM
Vijay's Avatar
Vijay Vijay is offline
Vijay is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by 03_PSD View Post
wow.....14 mpg with all stock but a chip.............................you pulling our leg
I guess he is, my dually does not crank out anything more than 14MPG!
Chip, Mug or tug!!!
no offense, the truck looks good for a daily driver/mall-crawling( if the $ does not matter running it), but I feel the tires are way too high! it's personal taste, I guess. In essence, too much tires for me, I would invest in a Jeep for off road purposes or better a H1!
  #53
Old 05-29-2008, 04:44 PM
countryboy116's Avatar
countryboy116 countryboy116 is offline
countryboy116 has a very good reputation on FTE.countryboy116 has a very good reputation on FTE.countryboy116 has a very good reputation on FTE.
Were simply looking out for your safety and ours, and the overall longevity of this truck, its a nice truck that has some potential with some work done to it. And if im not mistaken didn't you say that you had someone else build it, you just simply changed the panyard bar (so wouldn't that mean that you actually sat on your a$$ while someone else built it? sounds a little hypocritical to me) don't take everything so offensive, its just constructive criticism.
  #54
Old 05-29-2008, 06:45 PM
Greywolf's Avatar
Greywolf Greywolf is offline
Greywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputation
Truer words were never spoken! Duane Allman said it best: "Wasted words - will never be heard..."
WHATEVER the mileage is, I LIKE THAT TRUCK!!!
  #55
Old 05-29-2008, 06:49 PM
Greywolf's Avatar
A) The stock 7.3 with a chip has absolutely no problem turning the tires that are on it now!
B) The axles are stock on it and the gears are being swapped out currently for a set of 4.88's
C) I did a full Stage 2 tranny that does not seem to have a problem with the oversize tires. (And it is warrentied if it does)
D) The brakes are stock. However, I purchased a 350 since the brakes are beefier than the stock 250.
E) What would a truck be without an aftermarket sound system?! haha
I am fully aware that the truck is not near as tough as some out there. This is how I purchased the truck and It is my mission to make it one of the toughest out there. I am starting with the tires bc the ones that are on it now are rated to 2k pounds and 15 mph. Currently, it is without a doubt a pavement pounder. I am just taking it step by step into making this one of the toughest trucks around!
THAT is the best way to do it.
You're doing two things that I applaud loudly:
1) Taking your time.
2) Thinking BIG to begin with.
It'll all work out....
Quote:
Originally Posted by Greywolf
What do you mean I can't have a dream? I dream every night, and sometimes during the day. If you mean to tell me I can't make my dreams come true - I hope you have NIGHTMARES about it...
  #56
Old 05-29-2008, 06:52 PM
liftedgrocerygetter's Avatar
liftedgrocerygetter liftedgrocerygetter is offline
liftedgrocerygetter is a splendid one to beholdliftedgrocerygetter is a splendid one to beholdliftedgrocerygetter is a splendid one to beholdliftedgrocerygetter is a splendid one to beholdliftedgrocerygetter is a splendid one to beholdliftedgrocerygetter is a splendid one to beholdliftedgrocerygetter is a splendid one to beholdliftedgrocerygetter is a splendid one to behold
That is a SWEEEEET looking ride you have! I wish I would have seen it when you were driving around PHX, oh nevermind, I probably would have wrecked my truck trying to get a better look at yours.
  #57
Old 05-29-2008, 07:00 PM
Greywolf's Avatar
That's what I'm saying - there may be shortcomings for now - but he's on the right track!
Axles for it will be interesting, unless he goes with a planetary hub system. ($$$$$$.....)
  #58
Old 05-29-2008, 07:08 PM
chrono4's Avatar
chrono4 chrono4 is offline
chrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to all
Thing is going to eat unit bearings left and right. If you want to go that big, either kingpin 60 for light use, or toploaders.
  #59
Old 05-29-2008, 08:38 PM
quadzjr's Avatar
quadzjr quadzjr is offline
just another Rockwell looser
quadzjr has a great reputation on FTE.quadzjr has a great reputation on FTE.quadzjr has a great reputation on FTE.quadzjr has a great reputation on FTE.quadzjr has a great reputation on FTE.
Quote:
Originally Posted by STGFordCrazy04 View Post
FAIL!
gdmf10cl
HAHAHAHAHAHAHAHA.......classic!
and agreed....
  #60
Old 05-30-2008, 04:20 PM
rugerman rugerman is offline
rugerman is starting off with a positive reputation.
Where do you keep the step ladder to get in that thing?
F-150 and Bronco Conversion...Has Anyone done it? WDScott 1987 - 1996 F150 & Larger F-Series Trucks 7 08-05-2015 10:36 AM
Bigger spare tire in factory spot..? tturbonegro Excursion - King of SUVs 10 09-29-2013 10:53 PM
Cupping tires? Road Noise, alignment? bnovak Escape & Escape Hybrid 10 01-03-2011 09:49 PM
Moving Front Cab Body Mount Kirbys73F100 1973 - 1979 F-100 & Larger F-Series Trucks 3 01-07-2010 12:18 AM
16 inch tires on 16.5 rims fordboy_52 General Automotive Discussion 9 12-04-2009 12:15 AM
Tags
32, adpaters, f350, ford, friday, inches, lift, lightning, monster, monstertrucks, pics, truck, trucks, usa6x6, vidalia, white
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
