Hi guys.
I've been going through this forum for a while looking for info and I figured I'd just ask about my situation.......
Here's the background. I have a 1986 F150 flareside with a 300 6, 4 sp manual tranny. I have NO idea what tranny it is nor what rearend the truck has. The engine is nearing the 275000 mark and it's tired. I just pulled a 73 351c 2barrel out of an old donor mustang. It had an automatic...
Now, I'm planning on doing a STOCK rebuild on the 351c( hone cylinders, re-ring, bearings, the works.) I do want to put in a mild cam since I've read that these years had lower comp ratios than others. I also plan on installing an Edelbrock Performer manifold with a 4 bl Holley carb. I will change rockers to roller type if need be but if it's not needed, I won't. I'm not looking for huge power, I have a 331ci fox body mustang with a good heads, cam, intake for that...... This is just a daily driver truck that I want a good engine for. I read a few threads ago that the Comp XE256 cam was a good one but the spec sheet on the website shows that it requires a new valvetrain, higher comp ratio, etc. Is this accurate? Is there a better cam lifter kit for my stock engine? I don't want to go into a new valvetrain setup for this. I'll eventually need help finding a 164 tooth flywheel for it but I'll cross that bridge when I get there.
Next thing is the distributor. My truck has electronic ignition with the dist. mounted controle module. Is there a dist that will fit the 351c that has the module mounted to it from a newer truck? Like one with a windsor? Thanks for any help and I look forward to knowing you guys!!
