Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V10 (6.8l)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-27-2008, 08:29 AM
SLE's Avatar
SLE SLE is offline
SLE is gaining momentum as a positive member of FTE.
Towing in 2nd gear!
I'm just wondering how many have towed for any extended periods in 2nd gear (4R100). I recently purchaced a newer larger boat which I pull in tandem behind by camper and found a few situations over the weekend where I had to drive between 40-55mph into a 20-40mph head/side wind and 3rd gear at less than 2k rpms just couldn't get the job done. I shifted the ol girl into second and held it there. I ran it this way for 30-45 mins twice over the weekend and other than a very dismal fuel mileage it seemed to work just fine and was nice to have lots of power on tap when heading up a few of the larger hills.
I am just wondering if I can damage any thing doing this? The RPMs ranged between 2,800ish and 3,400ish and not a single one of my gauages so much as moved (not that there worth a hoot anyway). Last question does the TC stay locked in second? I am almost sure it does otherwise I would have fried my trany but I just thought I'd ask.
Thanks
__________________
2003 F250 Super Duty XLT Sport 4x4 - Crew Cab Short Box - 6.8L V10 - 3.73LS - AR Slider 16x8 Rims - 75/285/R16s - "Y" pipe mod -
IT'S JUST STUFF!!!!! RELAX
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-27-2008, 08:36 AM
benr0 is starting off with a positive reputation.
Done on that on several occasions myself past few years. Ain't got no problems from it.
These V10's you can just be wound up, and let um go with no problems.
__________________
2001 TRed F250 Lariat CC SB,4x2, Camper Pkg., V10, Auto, 3.73LS, Heated seats, Bed X-tender,Ford Flaps,Catch-all,RollNLock. 7200# Me, Wife, 2 teens, gas and gear for weekend.
  #3 (permalink)
Old 05-27-2008, 09:41 AM
Mark Kovalsky's Avatar
Mark Kovalsky has a great reputation on FTE.Mark Kovalsky has a great reputation on FTE.Mark Kovalsky has a great reputation on FTE.Mark Kovalsky has a great reputation on FTE.
The torque converter can lock in second gear if your foot is far enough into the throttle.
__________________
Mark
Former Ford automatic transmission engineer, 1988-2007.
  #4 (permalink)
Old 05-27-2008, 10:34 AM
dkf's Avatar
dkf dkf is offline
dkf is gaining momentum as a positive member of FTE.
No problem towing in 2nd. I pushed my truck on I81 towing last weekend up a constant steep grade that must have been at least 3-4miles long, 75-80mph in 2nd over 4300rpm, no problems. The engine will rev high all day if need. Watch the trans temp though and installing a larger cooler is a good idea. My trans temp jumped 10 deegrees after about 15 mins of constant climbing, but the highest temp was 161 deg F. The TC will lock up.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
