where is power rear slider switch located? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 05-27-2008, 12:57 AM
kengarchow kengarchow is offline
kengarchow is gaining momentum as a positive member of FTE.
on the 99-04 SD?
thanks
Old 05-27-2008, 12:59 AM
RACERX7775's Avatar
RACERX7775 RACERX7775 is offline
PROFESSIONAL KNOW-IT-ALL
RACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to behold
it was offered??? i thought it was 05+.....
Old 05-27-2008, 01:03 AM
better add the 05-07 location to the question then
thanks
Old 05-27-2008, 03:30 AM
tazo's Avatar
tazo tazo is offline
tazo is gaining momentum as a positive member of FTE.
The switch is on the dash right hand lower side. Sorry but I dont have pics.
Old 05-27-2008, 06:38 AM
350z 350z is offline
350z is starting off with a positive reputation.
My 04 has it .
Old 05-27-2008, 06:48 AM
donjamer's Avatar
donjamer donjamer is offline
donjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputation
On my 06 it is in the middle of the dash just under the backup alarm shut off button..
Here is a picture.... It is just under the air vent and above the shift ****..
Old 05-27-2008, 11:15 AM
RACERX7775's Avatar
see, shows you what i know, i have an excursion. i should have stayed out of this one. sorry.
Old 05-29-2008, 03:17 PM
Beerstalker's Avatar
Beerstalker Beerstalker is offline
Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.
Mine's in pretty much the same spot as Donjamer's. A little further right because I have the ESOF switch there (don't have reverse sensors though). I love th rear slider and use it all the time.
Old 05-30-2008, 07:56 AM
PERFORMANCE RED PERFORMANCE RED is offline
PERFORMANCE RED is starting off with a positive reputation.
Does anybody know if they made a plate like that for the rear window but without the ESOF and parking sensor? So it would only have the window switch in it?
Old 05-30-2008, 08:27 AM
Dogwood36322's Avatar
Dogwood36322 Dogwood36322 is offline
Dogwood36322 is starting off with a positive reputation.
My 04 has the rear slider and has a panel for the switch located similar to Beerstalkers. I also added after market backup sensors and placed the on/off switch in the same panel.
Old 05-30-2008, 10:12 AM
RACERX7775's Avatar
duh, i forgot that i had this dash cover in my basement. i bought it when i thought i could update mine in my excursion. i still have it and its for sale......cheapppp. here is a pic.
Old 05-30-2008, 12:24 PM
I'm sure FTEPartsGuy could figure out what the part is. What exactly are you trying to do? What year truck are you working on? This panel won't fit in the 99-04 dash if you are thinking of doing that.
Old 05-30-2008, 01:33 PM
dfooch's Avatar
dfooch dfooch is offline
dfooch is starting off with a positive reputation.
I test drove an 05 F350 last December and I believe it had the panel with just the slider switch on it.
Not to hijack the thread, but does anyone know if there is a kit to add power to the rear slider? I have the slider, but would really like to install a power switch to it if it is possible.
Old 05-30-2008, 02:20 PM
FTE/PARTS-GUY FTE/PARTS-GUY is offline
Former Vendor
FTE/PARTS-GUY has a great reputation on FTE.FTE/PARTS-GUY has a great reputation on FTE.FTE/PARTS-GUY has a great reputation on FTE.FTE/PARTS-GUY has a great reputation on FTE.FTE/PARTS-GUY has a great reputation on FTE.
Quote:
WHAT? I can do it!
what do you need?
Ed
Old 05-30-2008, 03:42 PM
The power sliding rear window is a whole different window than the manual sliding rear window. You would have to replace the window and possibly run all the wiring as well as installing the switch.
Quote:
Originally Posted by FTE/PARTS-GUY View Post
WHAT? I can do it!
what do you need?
Ed
He is looking for the little dash insert where the ESOF, Reverse Aid, and power sliding window switches go on the 05-07 trucks. He only wants the one with a cutout for the power sliding switch though, not the ESOF or Reverse Aid cutouts.
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 03:27 PM
Can someone explain this to me? 1987 - 1996 F150 & Larger F-Series Trucks 11 03-09-2016 12:40 PM
ooops Aerostar 5 01-14-2015 03:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 06:14 AM
DPSE Roachfood 1987 - 1996 F150 & Larger F-Series Trucks 3 03-11-2002 10:21 PM
Tags
05, 2004, 2005, change, f150, f250, ford, location, power, rear, slider, sliding, superduty, switch, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
