Front End Alignment... - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 05-26-2008, 08:02 PM
gvrangr98 gvrangr98 is offline
gvrangr98 is starting off with a positive reputation.
Question Front End Alignment...
what is actually done when I pay $93.74 for a front end alignment on my 98 4X4 3.0 xlt?? what is it "THEY" actually did?! Can/will someone walk me through this? thanks in advance.
Old 05-27-2008, 04:46 AM
Dan Robertson Dan Robertson is online now
Dan Robertson is starting off with a positive reputation.
I'm not sure what is all involved on the 4x4. On a 98 2 wheel drive with the coil spring suspension, there is no caster/camber adjustments. All they do is adjust the toe in, something that can easily be done at home.
Old 05-27-2008, 07:40 AM
MazdaRangerGuyInSTL MazdaRangerGuyInSTL is offline
MazdaRangerGuyInSTL is starting off with a positive reputation.
Maybe not.. it is possible to adjust camber/caster if an adjustment kit has already been installed onto the upper control arms...
Do you happen to have a copy of the alignment printout handy? That will tell us what has been done. If you want post it and I'll decode it for you.
Old 05-27-2008, 04:41 PM
well i haven't had it done yet. I'm shopping around for the cheapest service. I just want to know what it is they adjust? what they do and how they do it. does any one know for sure?
Old 05-27-2008, 04:47 PM
bigrigfixer's Avatar
bigrigfixer bigrigfixer is offline
The Pacifier
bigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputation
Do you even need an alignment?
Does it pull one way or another?
Are your tires wearing funny? For that matter, are your tires inflated properly?
You really gotta whack something to throw your alignment out.
Old 05-28-2008, 09:12 AM
sorensenj sorensenj is offline
sorensenj is starting off with a positive reputation.
Last year I had my 2001 3.0 4x4 aligned. Cost me $75 and from what I can tell they really were only able to adjust the toe. The caster/camber adjustments needed an adjustment kit installed for more added expense (can't remember how much more but it seemed like it was enough). I told them to check the alignment first and see if the kit was even needed. Turned out everything was within spec on the caster/camber adjustments so I passed on the install, maybe next time I won't be so lucky. I'm not a fan of this nickel & diming Ford is pulling on us but I was assured by the alignment guys that all the car companies are doing it. I can't verify that because all I have is Fords.
Old 05-28-2008, 07:01 PM
reddog99 reddog99 is offline
reddog99 is starting off with a positive reputation.
$93.74 is pretty darn steep for just an alignment. I get mine done for $40 her in So Cal. For that amount, better be replacing parts...
Front End Alignment Long Island 429poweredf350 New York Chapter 0 04-16-2014 07:35 PM
1989 F150 alignment specifications Freightrain 1987 - 1996 F150 & Larger F-Series Trucks 9 05-08-2012 07:43 PM
2 or 4 wheel alignment? spr1516 1999 to 2016 Super Duty 14 03-10-2009 11:37 AM
Avg Front End Alignment Cost? UGA33 1999 to 2016 Super Duty 16 12-05-2007 12:51 AM
Pop in front end Ultramagdan 1997 - 2003 F150 2 09-22-2000 11:02 AM
Tags
1998, 1999, 2000, 2002, 95, adjustment, align, alignment, camber, cost, edge, end, ford, front, ranger
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
