screeching serpentine belt - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 05-26-2008, 08:10 PM
billj6 billj6 is offline
billj6 is starting off with a positive reputation.
Cool screeching serpentine belt
'99 2x4, 3.0, auto. 96,000 mi.
Replaced belt and tensioner 20,000 miles ago. It squealed before and squeals now. Happens worst in cold, wet weather. One quick, small squirt of Armor All protectant on the inside of the belt while in motion silences it instantly and completely. This, and the fact it's been going on so long tells me it's the belt and not a pulley. Just wonder why it squeals. Engine runs great. Is there a dressing that lasts for a month or so instead of Armor All once a week?
Old 05-26-2008, 09:56 PM
kpwall kpwall is offline
kpwall is starting off with a positive reputation.
Hey, they make special belt dressing that comes in a spray can. I would think that the armor all is just making it slip a little bit and that is why it stops the squeeling. The belt dressing is made to give it more friction I think so it would do the opposite of what the armor all is doing. Do the belts squeel on day one of install or does it take awhile for them so start?
Old 05-27-2008, 01:31 AM
bigrigfixer's Avatar
bigrigfixer bigrigfixer is offline
The Pacifier
bigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputation
Try the idler pulley.
Mine though, it was a combination of all 3.
Old 05-27-2008, 08:43 AM
MazdaRangerGuyInSTL MazdaRangerGuyInSTL is offline
MazdaRangerGuyInSTL is starting off with a positive reputation.
Mine does all that too. Do NOT put anything on the belt it just makes it worse long term.
I had a very slight coolant leak at the timing cover gasket.. I have a feeling a drop or two of antifreeze was getting on the belt.. but maybe I am wrong.
I just dealt with it... it usually went away within 30 seconds anyway
Old 05-27-2008, 11:19 AM
rebelyell618's Avatar
rebelyell618 rebelyell618 is offline
rebelyell618 is starting off with a positive reputation.
try a goodyear gatorback belt if you feel that is the only problem, it a very quiet belt for a very fair price.
Old 05-27-2008, 07:22 PM
02xlt3.0's Avatar
02xlt3.0 02xlt3.0 is offline
02xlt3.0 is starting off with a positive reputation.
Quote:
Gatorback solved my squealing belt problem too. About $35 at auto zone and worth it. I'll never have anything else.
Old 05-27-2008, 11:45 PM
herman391's Avatar
herman391 herman391 is offline
herman391 is gaining momentum as a positive member of FTE.herman391 is gaining momentum as a positive member of FTE.
Don't put anything on the belt the sprays just cause the belt to slip which is worse in a way. I had someone tell me to put dielectric grease on there and it worked but it all built up in the ribs of the pulleys so I wouldn't put that on there either. My problem turned out to be the bearing in the idler pully. It's a simple 10 minute job.
Old 05-28-2008, 06:47 PM
I mentioned that I replaced the tensioner pulley with the last belt. The short spray of Armor All hits the inside of the belt and causes the noise to stop instantly. That doesn't sound like the pulley is causing the noise.
Old 05-28-2008, 07:55 PM
Bikeitswift Bikeitswift is offline
Bikeitswift is starting off with a positive reputation.
You didn't tell us what brand belt, tensioner, etc. you used. Some members have posted poor results with the cheapest belts.
On my '02 3.0, only 43,000 miles, I started getting the "squeal" now and then. The idler pulley had play I could feel by hand (engine off, of course), and then I could sight across the engine pulleys and see that the tensioner pulley was canted at an angle...indicating wear down there...so I had all three (idler, tensioner, belt replaced with Motorcraft parts...which were a few dollars cheaper than the parts store parts.
Old 05-28-2008, 09:25 PM
herman391's Avatar
Quote:
Idler pulley and tensioner pulley are in two different places on the engine though. It could be that you replaced the one that wasn't making the noise.
Old 05-28-2008, 09:28 PM
azu azu is offline
azu is starting off with a positive reputation.
I had same problem for about 2 years. Replaced tensioner pulley and belt a few times. Each time it corrected the problem but within a few months it was back. I changed the tensioner assembly and all has been good for 3 years now!
Old 06-09-2008, 07:29 PM
RangerRuss RangerRuss is offline
RangerRuss is starting off with a positive reputation.
MazdaRangerGuy has the right idea - there is something be it oil. coolant or ? that is on one of your pulleys and transferring to the belt - see this all the time. Belt dressings do not work on serpentine belts. My suggestion is to remove your serpentine belt and thoroughly clean all of your pulleys with alcohol or electrical cleaner watching carefully for the cause of the oil/grease/ whatever on one of the pulleys. You may be able to clean the existing serpentine belt and it will be O.K. however I agree that the Gatorback is a great belt and relatively inexpensive.
Russ
2005 f150 xlt 4.6L Squealing noise Chasetgd 2004 - 2008 F150 0 02-10-2015 09:34 PM
2005 f150 4.6L squealing noise Chasetgd New Member Introductions 0 02-10-2015 09:13 PM
05 ford ranger edge 4.0 squeaky belt 77mud Ranger & B-Series 10 08-24-2014 04:38 PM
Weird belt squeal? Truck Guy99 1987 - 1996 F150 & Larger F-Series Trucks 5 04-26-2014 10:00 AM
93 7.3L IDI Belt Squeal Lowedogg Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 08-26-2013 09:29 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
