Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 05-27-2008, 07:11 PM
fuzzy1626's Avatar
fuzzy1626 is starting off with a positive reputation.
Mine stays parked most of the time and the ranger has been pressed back into service. Bought two locking fuel caps from LMC for the diesel since it's sitting with over $150.00 worth of fuel at todays price.
__________________
Tony 1994 F250 XLT ext. cab,long bed,7.3 IDI factory turbo,4x4,manual hubs E4OD,4.10 gears, K&N air filter,PSD oil filter, TruxPort tonneau cover, 172,000 miles and counting. 88 Ranger 2.0, 5 speed,130,000 mi.,bought new. NC Chapter Member.
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 05-27-2008, 08:09 PM
George D.'s Avatar
George D. is starting off with a positive reputation.
Quote:
Originally Posted by stevilknevil View Post
remember that in the next election.
Um what? George Bush isn't the one setting fule prices and the democrats are just as deep in oil. With the craptastic two party system we have we truly are screwed. The only information we get about whos running is from the new wich is nothing more than libral or conservative propaganda depending on the chanel.
__________________
94 F350 Crew Cab Long bed 4X4 7.3L IDI Factory Turbo, AKA The Land Yacht. E4OD, 4.10 posi. Getting further from stock with 35 inch BFG alterains on 16 inch micky's, straight pipe, Triple A-piller pod with pyro, boost, modifyed stock oil presure gauge, tc lock light&switch
  #18 (permalink)
Old 05-27-2008, 08:30 PM
tbone91 is starting off with a positive reputation.
On my last trip from CA to TX, it sure seemed like there was a *huge* difference the the quality of the fuel along the way. Has anyone had good experience changing where you fill up?
Even here in CA, there are still non-emissions compliant cars from the 60s driving around. As long as everything is basically stock, they're grandfathered in. Hopefully, that won't change anytime soon...
__________________
91 F350 dually crew cab, Rebuilt E40D + TC, ATS turbo, stock intake & exhaust
  #19 (permalink)
Old 05-27-2008, 09:34 PM
George D.'s Avatar
In Ca 1975 or older is exempt from emisions testing.
__________________
  #20 (permalink)
Old 05-27-2008, 10:22 PM
midapo is starting off with a positive reputation.
Quote:
Originally Posted by David85 View Post
midapo, what is your:
Axle ratio?
2wd or 4wd?
tire size?
lift kit? (if any)
Cruise speed?
Distance for commute?
2wd, 235-85-16, I don't know my axle ratio, although being a 1 ton I would say it is low, it is set up for pulling a fifth-wheel. I average putting about 150 miles a week on it. I drive country roads with about 8 stop signs to get to work, usually driving no faster than 70 mph. No lift kit.
One other thing. both gas tanks will run out of gas with 1/4 left in the tank. I assume the stinger on the end of the pickup in the gas tanks has broken off. Or could it be the fuel pump and would either of these things hurt mileage?
  #21 (permalink)
Old 05-28-2008, 12:16 AM
David85's Avatar
David85 is gaining momentum as a positive member of FTE.
For the fuel tanks, the pickup tubes are probably broken off. It would not have much affect on performance unless its ingesting air, and that is something that you would notice (surging, stalling and black smoke). A bad fuel pump or injector pump would certainly affect MPGs, but it would also affect power.
It sounds like this may not be the best truck to use as a daily driver if it is geared as a towing rig. Normally I would suggest a gear change because its not very expencive with a 2wd, but if its being used as a towing vehicle for a 5th wheel, that may not be a good idea. Are you still using it as a towing rig, or was it set up that way by a PO? If you don't mind loosing some low speed grunt, than a gear change would probably help, but we need to know your current ratio first.
I calculated a monthly operating cost of $180 @ $4.00 per gallon for fuel. At that price you could almost afford to buy a small econobox for commuting and park the truck. Not sure what your insurance cost is, but I am paying under $100 per month for my 86'.
__________________
1986 F250HD Ex cab Fresh built up 6.9L diesel Lariat AC leather seats power everything w/full cluster, sterling rear 3.08LS gears, E4OD trans, ram intake ATS 088 turbo
1986 F150 Ex cab Lariat rollercam 5.0L on LPG AOD trans 3.55 gears 390 000Ks
  #22 (permalink)
Old 05-28-2008, 12:17 AM
optikal illushun's Avatar
optikal illushun is starting off with a positive reputation.
makes me glad i fill up once a month n has another truck!
__________________
93 F150 XLT 4x4
Modded 300/Built E4OD
RC 2 1/2" lift
33 ProComp MTs
15x8 AR 147's
Crane 503905 cam
Crane coil
Taylor wires
Hedmen headers
1988 F350 Custom 4x4
7.3 IDI/ZF
RayWel lid w/ Opti'ized ram air
"G" codes
True 2 1/4" duals w/ packs
315/75/16 ProComp Xtreme ATs
16x8 White waggies
Alpine/Infinity stereo
3G soon
  #23 (permalink)
Old 05-28-2008, 01:57 AM
1994diesel's Avatar
1994diesel is starting off with a positive reputation.
nu uh.
Quote:
Originally Posted by timcos View Post
Why not move to running veggie oil...not biodiesel but straight veggie oil?
Does require some work for collection and filtering, but heck who cares what the mileage is when it only costs 33 cents a gallon?
Just my couple of pennies thrown in.
Tim
you've got the right idea, aternative fuel, but biodiesel is the better choice, it is chemically changed veg oil, it thins it out and makes it so you can run it with out any mods. wvo is free, biodiesel would cost you about $.33 a gal.
what im doing is drivn my motorcycle as a daily driver and use my truck for play, seeing that my motorcycle get 60mpgs on a bad day, its pretty good, 2.5 gal. of gas a week.
__________________
94 F-250 Turbo Diesel, 7.3L IDI, E4od, 4x4, long bed, ext cab, pyrometer, ATS boost gauge, pump turned up 2 flats, Straight pipe
93 F-250, 7.3L IDI, E4OD, 4X4, long bed, ext cab, straight pipe... almost.
  #24 (permalink)
Old 05-28-2008, 06:48 AM
Chief Honcho in Charge
timcos is starting off with a positive reputation.
The WVO would not be completely free...does take some fuel to get it (even if wvo is the fuel), wear and tear (very small cost), time, the filtering process, filters and some place to store it.
I did not realize processing biodiesel is as low as 33 cents a gal...I was thinking more like 2 bucks...but i have no experience there at all.
What does one do with the bi product of the processing other than the biodiesel?
BTW...I am buying my first diesel this week and am learning quickly.
Tim
  #25 (permalink)
Old 05-28-2008, 07:23 AM
No surging or black smoke, runs great. I am selling my fifth wheel, never to buy another. What is involved in a gear change? And hoe do I find out what mine is?
You are right on the operating cost. My insurance is less than $50.00 a month.
  #26 (permalink)
Old 05-28-2008, 12:14 PM
David85's Avatar
Changing the differential gears is not a big deal. You just have to read up on the procedure, and not rush when you do it. I had no prior experience with gear swaps when I pulled 4.10 gears for the 3.08s that I am running right now.
You will need a torque wrench, 1/2" drive socket set, breaker bar to match and a cheater pipe. Micrometer will help, but even that can be avoided. The trick is to make sure the gears mesh properly. For that you simply use some ink on the teeth, and observe the tracking pattern. Reusing the factory shims gave me the proper gear tracking.
There are 3 ways to check the axle ratio (from easiest to hardest)
1)on your next drive, observe the tachometer reading next time you are at 70 MPH and we can calculate the gear ratio.
2)read the axle ratio code on the drivers side door and we can decode it here
3) the most accurate way would be to remove the differential cover and count the number of teeth on the differential gears. This is not really necessary unless you suspect the truck may have been modified in the past.
If step 1) and 2) both produce the same results you can be pretty sure that the result is accurate.
__________________
  #27 (permalink)
Old 05-28-2008, 01:51 PM
I will get all that info together. How much better was your gas mileage after the change?
  #28 (permalink)
Old 05-28-2008, 04:13 PM
My rpm reads just below 2000 @ 70 with overdrive, 2700 to 2800 with overdrive off. The number under axle on the door is 39. thanks!
  #29 (permalink)
Old 05-28-2008, 04:26 PM
fuzzy1626's Avatar
39 should be a 3.55 gear.
__________________
  #30 (permalink)
Old 05-28-2008, 08:43 PM
David85's Avatar
If you have 3.55 gears than you are already close enough that a gear change will not be worth your while. You should see about 1850 RPM at 70 MPH. That is a good RPM for fuel economy.
My truck had a C6 transmission with 4.10 gears when I bought it. Top speed was 75 MPH and fuel economy was 9 MPG @ 60 MPH.
Going to 3.08 gears pushed the MPGs up to 15 for the average city/highway. Better fuel economy was possible on good days. More recently, I am towing almost all the time, so I don't know what the best economy for running empty is right now with the turbo and OD tranny.
I still have a feeling that you should be getting better MPG than 13.3. Do you know the age of your injectors and injector pump? Upgrading the downpipe might help economy, but I have a feeling that it won't make much of a difference running empty.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
