Go Back   Ford Truck Enthusiasts Forums > Bronco > Big Bronco (1978 - 1996)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-26-2008, 07:22 PM
S.P. is starting off with a positive reputation.
Question Ehx. Smoke!!!!
HI ALL. YOU WILL HAVE TO FORGIVE ME, BUT I MOSTLY SPEND MY TIME ON THE IDI PAGE. A GUY I KNOW HAS A 1990 BRONCO MAN.TRANS 351ci. AND IT SMOKES LIKE CRAZY... AT IDLE AND DRIVING.... IT IDLES SMOOTH AND SEEMS TO RUN REAL NICE...I WAS JUST WONDERING IF THARE ARE SOME THINGS THAT WOULD CAUSE THIS WITH THE FUELINJECTION OR COMPUTER STUFF.......BEFORE MY FORD I HAD A CHEVY... SO I KNOW NADA ABOUT FORD FI. BRONCOS...............PS THE SMOKE IS BLUE AND IT COMES OUT THE PVC AND FILLER HOLE........(SORRY FOR ALL CAPS BUT I DIDNT WHANT TO GO BACK AND RETYPE THIS WHOLE THING...LOL...) THANKS FOR ALL THE HELP...S.P.
__________________
"YOU'RE JUST JEALOUS THAT THE VOICES TALK TO ME"
1991 F250 X/cab, 4X4, 7.3l, w/ATS Turbo, Lariat, egt & psi gauges, 33" tires, and now with a 5th wheel hitch..
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-26-2008, 07:27 PM
boulderbronco is starting off with a positive reputation.
sounds like a hole in a piston. What does the smoke smell like? Fuel? Oil? Antifreeze?
__________________
Chris,
93 5.8L, 6" Superlift, Superrunner Steering kit, Warn hubs, BroncoAir front winch bumper, Warn M12000 winch, BroncoAir OBA System, AGR P/S Pump, K&N custom intakes, 4.88's, Front ARB, PIAA 90 Series fog/driving lights. Owner of Broncoair.com
  #3 (permalink)
Old 05-26-2008, 07:42 PM
ehx.smoke
THANKS FOR SUCH A FAST REPLY.... that sounds about right...smells like fule to me...I think you hit it on the head.....it got hot and he checked the rad. verrrrrry low he added water to it (hot) I told him to stop,and wait for it to cool but water was leaking out the bottom of rad....OH and the intake hoses/air filter and butterflys have oil/gunk all over and in them...
__________________
  #4 (permalink)
Old 05-26-2008, 08:32 PM
Quote:
Yeah. You definatly have a problem. He's got real bad blow by. Meaning the compression rings are not doing their job and the compression is leakin into the combustion chamber and out through the PCV valve and breather tube. Or worse he has a hole in the piston. The only thing that I am confused about is the radiator thing. That is not a good thing obviously but usually when that happens you blow a head gasket and not the whole engine. But if he was running it crazy hot for to long the oil could have broke down and the pistons scarred the cylinder walls and damaged the rings. I would start by getting a compression test done. Good luck.
__________________
Chris,
  #5 (permalink)
Old 05-26-2008, 08:43 PM
THANKS boulderbronco I will pass the info. on to him.....
__________________
  #6 (permalink)
Old 05-26-2008, 09:01 PM
No problem. Good luck.
__________________
Chris,
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
