Archived MO Buy/Sell/Trade Ads - Page 5 - Ford Truck Enthusiasts Forums
Missouri Chapter Join Chapter , Leader:tcbofade
Closed Thread
  #61
Old 05-09-2006, 02:58 PM
F250_Rumbler F250_Rumbler is offline
F250_Rumbler is starting off with a positive reputation.
Tonneou cover off of a 2005 Chevy Silverado short-bed. less than 8 months old. $500 OBO.
Garry 314-369-8124
  #62
Old 05-23-2006, 07:52 PM
ericsmith32 ericsmith32 is offline
ericsmith32 is gaining momentum as a positive member of FTE.
Airforce One Intake - Fits 99-03 5.4L F150, I don't know about the 97-98 years but it could work. Used for about 3 years cleaned once which was recently. Still has a mirror shine. Located in the KCK area. $100
  #63
Old 05-26-2006, 03:14 AM
Brian_B's Avatar
Brian_B Brian_B is offline
Brian_B is gaining momentum as a positive member of FTE.
Wanted to buy or trade: ford tailgate 53-72, short bed, step side. It needs to be the one that is approximately 19" tall. Gate must be in great condition. No junk.
I have an express bed tailgate (20 3/4" tall) that is nearly mint if anyone needs one and wants to trade.
If I can't find one, I will have to shorten the one I have, but I would rather avoid the work.
I am located in Mountain Home, AR.
Please PM me with info if you have one.
Thanks,
Brian
  #64
Old 05-26-2006, 10:38 PM
87ford4x4inline6 87ford4x4inline6 is offline
87ford4x4inline6 is starting off with a positive reputation.
Cleaning out the garage and the yard.
Up for grabs a 1983 F250 parts only, I bought this truck for the front clip, doors and was going to swap axles but it had the same front axle my flat bed has so I just took the hubs off.
full size bed in fair shape $150
Front axle belive to be a d44 hd 3:55 gears minus the hubs $150
rear axle not sure what it is no tag, minus the springs $150
rear and front drive shafts $30 each or $50 pair
I have 2 transmissions that came with this truck, I know nothing about them, previous owner was swapping out the 4 speed to a auto.
C-6 and a 4 speed belive for a big block. motor that was pulled was a 352. $150 each
I also have 2 different transfer cases for the above transmissions. I will look sunday and see what they are. $150 each
2 sterring colums one for the manula and on auto make offer
All is located in Missouri just north of the 166 milemarker on interstate 70 (danville area)
would consider trades (looking for a 79 dana 44 with radius arms and mounts and a 9inch to swap under my bronco ii)
  #65
Old 05-31-2006, 08:34 PM
BigGreen'77 BigGreen'77 is offline
BigGreen'77 is starting off with a positive reputation.
Ive got an aftermarket front tank I took off my truck on ebay for .99 cents.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=8071203756
  #66
Old 06-16-2006, 03:57 PM
Looking for a rear window for a 95 extended cab ranger. The window should be the frame type.
Also still have for sell C6 transmission and a 4 speed for a big block ford. A np208 and a 1345 transfer case. Plus a rear window for a ranger molding type.
  #67
Old 07-02-2006, 08:19 PM
lil_dq's Avatar
lil_dq lil_dq is offline
lil_dq is starting off with a positive reputation.
My 02 FX4 is for sale would like to get about 16,000 for it
looking at a 00 Excursion diesel so would like to get out from under it.
  #68
Old 07-03-2006, 01:23 PM
jonredbird jonredbird is offline
jonredbird is starting off with a positive reputation.
Just got new SD....FOR SALE, set of Pirelli 265/70/17 tires. Less than 100 miles. $250 firm. I'm in Springfield,MO. Will meet someone within an hour drive. Please respond via PrivateMessage if interested.
  #69
Old 07-04-2006, 11:41 AM
KCSport's Avatar
KCSport KCSport is offline
KCSport is starting off with a positive reputation.
Selling the DEPO Black Harley Headlamps off my truck. They fit a 2004 and up F-150. Looking to get $120 shipped.
  #70
Old 07-14-2006, 09:34 PM
bobf100's Avatar
bobf100 bobf100 is offline
bobf100 is starting off with a positive reputation.
Looking for 40's or 50's Telephone truck or telephone bed
I'm looking for the bed or complete telephone truck from the 40's or 50's. It doesn't matter if the bed is off of a non-ford as I believe the beds were the same. Generally the telephone company used trucks manufactured by the big 3 automakers but the beds were manufactured by a select few outside companies and were generic to fit all brands of trucks.
Would consider a telephone bed in any condition even if condition is so bad as to be only good for a pattern. I've got pictures of early telephone trucks that I can send to show what I'm looking for.
Guys - I'm talking about your standard 1/2 ton installer truck not the big heavy duty line trucks or pole setting trucks. The bed I'm looking for would fit on a standard F1 or F100 1/2 ton pickup.
Thanks - Bob
  #71
Old 07-15-2006, 04:37 PM
mindquake2003's Avatar
mindquake2003 mindquake2003 is offline
mindquake2003 is starting off with a positive reputation.
looking for a shell
Poor boy looking for a leer 122 cap for my '91 F150 shortbed.
  #72
Old 08-06-2006, 06:57 PM
19903024x4's Avatar
19903024x4 19903024x4 is offline
19903024x4 is starting off with a positive reputation.
1990 302 engine for sale. May need new rings condition of the inside of the engine is un-known. $100 OBO
1993 saturn SL2 202k miles on car has new engine, clutch, Throw out bearings and presure plate. Clutch leaks fluid and trans leaks. Engine doesnt run right and i'm not sure why. All parts on engine are brand new. Sun roof power everything. $2000 OBO
PM if interested.
  #73
Old 08-09-2006, 11:04 PM
Frrt's Avatar
Frrt Frrt is offline
Frrt is starting off with a positive reputation.
lookin: full bench seat from a 92-96 f150
would like to buy a bench seat from a 92-96 f150 or swap for my current 40/20/40 seat in my 96.
  #74
Old 08-29-2006, 07:26 PM
ninemmeterx2 ninemmeterx2 is offline
ninemmeterx2 is starting off with a positive reputation.
78 F150 for parts near K.C.Mo.
Truck has good 351M and C-6.Also has good w/s,rt door glass,rt frt fender,tail lights,headliner,tilt steering column,radiator,frt brake rotors and 15" aluminum slotted mags.Lt door is good except for a little rust on the bottom inside.Lt fender is good except for a small dent.A/C system is all there and blows cool air.9 inch rear end has 2.75 gears.No title.$250.00 for whole truck or will part out.
  #75
Old 08-31-2006, 03:45 PM
460429_freak's Avatar
460429_freak 460429_freak is offline
460429_freak is starting off with a positive reputation.
to bad you live so far I'd buy it...
Closed Thread
Archived MI Buy/Sell/Trade Ads Jimjdb1 Michigan Chapter 288 10-15-2016 06:54 AM
1992 E-350 7.3 Diesel Impac Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 28 08-20-2007 02:45 PM
Can anyone help? Clem B. Offroad & 4x4 3 01-29-2007 03:00 PM
Code P0460 04hdrider Ranger & B-Series 2 01-01-2007 07:20 PM
Ranger '01 Radio.... One more quation.... Pablo-UA Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 1 12-25-2006 01:37 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
17, 6367515136, 959c, craigslist, ford, grapplers, missouri, mud, nitto, rims, sale, tires, trucks, wheel, zora
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
