Should have part of the linkage bolted to the bell housing of the tranny with a long arm running back to the manual lever. The other end should be a linkage connecting to the steering column lever.
__________________
Stock 1978 F250 Custom regular cab 4x4 with 351M and 4 spd.
1991 Bronco silver anniversary, 5.8L EFI, E4OD swapped for C-6, otherwise still stock.
